1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: RBV value for Soft Channel motor not always being set properly on IOC startup
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: "Gregory, Ray" <gregoryrd at ornl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 9 Jun 2022 10:30:55 -0500
Ray,
You can work around the initialization problem by adding a calcout record to mirror the underlying motor's RBV:
record(calcout,"$(VM):rbvCalc")
    field(DESC,"Mirror RBV")
    field(CALC,"A")
    field(INPA,"$(M1).RBV CP MS")
And then using the calcout in the virtual motor's RDBL field:
  field(RDBL, "$(VM):rbvCalc")
Kevin
On 6/9/22 09:13, Gregory, Ray via Tech-talk wrote:
I am developing a Soft Channel motor to be a virtual motor that controls two other motors. The virtual motor is essentially a copy of one of the underlying motors and applies ‘adjustment’ moves to the other motor it controls in accordance with a pre-specified alignment profile (using a simple linear equation determined by calibration).
Most of this is working well. However, when the IOC starts, the virtual motor often fails to retrieve its RBV value from the underling motor. I’ve included the soft channel motor record below.
How do I fix this?
I am using EPICS base version 3.14.12.6. I am currently developing on my VM with Simulated motors. I’m not sure what differences to expect when I deploy this to an actual instrument.
So far I haven’t found a simple solution.
However, I have created horribly complicated solution that seems to work: I created another do-nothing Soft Channel motor and make it part of the virtual motor system, so now the overall virtual motor controls 3 motors, one of them being the do-nothing motor. Then, if the RBV value was not set properly at launch time, I move this do-nothing motor. This has the effect of sometimes properly setting the RBV of the main virtual motor. If that doesn’t work, I try it again, and again, up to some maximum number. I call this process ‘kicking’ the RBV.
It's a kludgy and nasty solution. I would very much appreciate knowing how to fix this in some simple way.
Thank you,
Ray Gregory
Oak Ridge National Laboratory
RE: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
Prev: PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
Next: Questions for epics 7 PVs: PV list with normative type Kim, Kukhee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: RE: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
Next: RE: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
