Thank you, Kevin! That works fantastically well.
Ray
Ray Gregory
Oak Ridge National Laboratory
-----Original Message-----
Sent: Thursday, June 09, 2022 11:31 AM
To: Gregory, Ray <gregoryrd at ornl.gov>; tech-talk at aps.anl.gov
Subject: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup
Ray,
You can work around the initialization problem by adding a calcout
record to mirror the underlying motor's RBV:
record(calcout,"$(VM):rbvCalc")
field(DESC,"Mirror RBV")
field(CALC,"A")
field(INPA,"$(M1).RBV CP MS")
And then using the calcout in the virtual motor's RDBL field:
field(RDBL, "$(VM):rbvCalc")
Kevin
On 6/9/22 09:13, Gregory, Ray via Tech-talk wrote:
> Hi,
> I am developing a Soft Channel motor to be a virtual motor that controls
> two other motors. The virtual motor is essentially a copy of one of the
> underlying motors and applies ‘adjustment’ moves to the other motor it
> controls in accordance with a pre-specified alignment profile (using a
> simple linear equation determined by calibration).
> Most of this is working well. However, when the IOC starts, the virtual
> motor often fails to retrieve its RBV value from the underling motor.
> I’ve included the soft channel motor record below.
> How do I fix this?
> I am using EPICS base version 3.14.12.6. I am currently developing on my
> VM with Simulated motors. I’m not sure what differences to expect when I
> deploy this to an actual instrument.
> So far I haven’t found a simple solution.
> However, I have created horribly complicated solution that seems to
> work: I created another do-nothing Soft Channel motor and make it part
> of the virtual motor system, so now the overall virtual motor controls 3
> motors, one of them being the do-nothing motor. Then, if the RBV value
> was not set properly at launch time, I move this do-nothing motor. This
> has the effect of sometimes properly setting the RBV of the main virtual
> motor. If that doesn’t work, I try it again, and again, up to some
> maximum number. I call this process ‘kicking’ the RBV.
> It's a kludgy and nasty solution. I would very much appreciate knowing
> how to fix this in some simple way.
> Thank you,
> Ray Gregory
- RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
- Re: RBV value for Soft Channel motor not always being set properly on IOC startup Kevin Peterson via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Kevin Peterson via Tech-talk
PVStructure vs Structure Madden, Timothy J. via Tech-talk
<2022>
2025
Removing battery/crystal from MVME 5100 Walsh, Thomas R. via Tech-talk
<2022>
2025
