Hi Eric,
I have nothing in writing, but I can tell you how I change the crystals out. I put the card on an ESD mat and then using a scribe(or small standard
jeweler screwdriver) I begin lifting the corner marked with the dot . Once I feel it move a little I go to the diagonal corner and lift up. Once this corner starts to come up, the crystal is loose enough to remove with my fingers. Go slow and watch not to
scratch the conformal coating of the PCB.
Tom Walsh
630-252-5621
- RE: Removing battery/crystal from MVME 5100 Stone, Eric D via Tech-talk
- Re: Removing battery/crystal from MVME 5100 Maren Purves via Tech-talk
RE: [EXTERNAL] Re: RBV value for Soft Channel motor not always being set properly on IOC startup Gregory, Ray via Tech-talk
PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
