1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Removing battery/crystal from MVME 5100
From: Maren Purves via Tech-talk <tech-talk at aps.anl.gov>
To: "Walsh, Thomas R." <twalsh at anl.gov>
Cc: "eric.d.stone at lmco.com" <eric.d.stone at lmco.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 9 Jun 2022 09:45:16 -1000
Basically.
The one thing to make sure is to get it in there the right way around.
The original reply was to me and that's the only thing to really be
careful about.
Maren
On Thu, Jun 9, 2022 at 5:12 AM Walsh, Thomas R. via Tech-talk
<tech-talk at aps.anl.gov> wrote:
> Hi Eric,
> I have nothing in writing, but I can tell you how I change the crystals out. I put the card on an ESD mat and then using a scribe(or small standard jeweler screwdriver) I begin lifting the corner marked with the dot . Once I feel it move a little I go to the diagonal corner and lift up. Once this corner starts to come up, the crystal is loose enough to remove with my fingers. Go slow and watch not to scratch the conformal coating of the PCB.
> Tom Walsh
> 630-252-5621
Removing battery/crystal from MVME 5100 Walsh, Thomas R. via Tech-talk
Prev: Re: PyEpics: Cannot connect to DEVICE Matt Newville via Tech-talk
Next: RE: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Removing battery/crystal from MVME 5100 Peter Milne via Tech-talk
Next: PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
