"The one thing to make sure is to get it in there the right way around.
The original reply was to me and that's the only thing to really be careful about."
Also be very careful not to break a leg off the crystal :-)
Tom – appreciate the response, thank you very much.
Hi Eric,
I have nothing in writing, but I can tell you how I change the crystals out. I put the card on an ESD mat and then using a scribe(or small standard jeweler screwdriver) I begin
lifting the corner marked with the dot . Once I feel it move a little I go to the diagonal corner and lift up. Once this corner starts to come up, the crystal is loose enough to remove with my fingers. Go slow and watch not to scratch the conformal coating
of the PCB.
Tom Walsh
630-252-5621
- Removing battery/crystal from MVME 5100 Walsh, Thomas R. via Tech-talk
- RE: Removing battery/crystal from MVME 5100 Stone, Eric D via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: PVStructure vs Structure Kasemir, Kay via Tech-talk
<2022>
2025
Re: Removing battery/crystal from MVME 5100 Maren Purves via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
