1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: PyEpics: Cannot connect to DEVICE
To: Thomas Feggeler <[email protected]>
Date: Thu, 9 Jun 2022 16:49:32 +0000
This could be a firewall issue.  Did you try temporarily turning off the Windows firewall?  It could be that caget has a firewall exception in place but Python does not.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Thomas Feggeler via Tech-talk
Sent: Thursday, June 9, 2022 10:29 AM
To: [email protected]
Subject: PyEpics: Cannot connect to DEVICE
Dear colleagues,
We have a new computer installation (Windows 10) with epics 7.0.4, python 3.6.4. When I try to connect with caget() directly over the command line to access a device, e.g.
Caget XXXX:XXXX:firmwarebuilddate
It immediately works.
When using pyepics over pycharm, or the python interpreter, the message „cannot connect to DEVICE“ is given out.
The Windows path variables are set, EPICS_CA_ADDR_LIST is set and imported into the pycharm environment.
In both pycharm and python console if I do the following:
import epics
import os
from epics import PV, caget, caput, cainfo os.environ['EPICS_CA_ADDR_LIST'] = 'XXX.XXX.XXX.XXX'
os.environ['EPICS_CA_AUTO_ADDR_LIST'] = 'NO'
print(caget('XXXX:XXXX:firmwarebuilddate'))
The same error occurs.
I’d kindly ask for your help.
Thank you
Kind wishes
Thomas
PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
Prev: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: Re: Questions for epics 7 PVs: PV list with normative type Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
Next: RE: PyEpics: Cannot connect to DEVICE Mark Rivers via Tech-talk
