1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: PyEpics: Cannot connect to DEVICE
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Thomas Feggeler <tfeggeler at lbl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 9 Jun 2022 20:34:48 +0000
I am copying this to tech-talk so everyone knows the solution.
-----Original Message-----
Sent: Thursday, June 9, 2022 3:33 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Subject: Re: PyEpics: Cannot connect to DEVICE
Dear Mark,
Thank you, that did it. I asked the IT to check and now it works.
Kind wishes
Thomas
> Am 09.06.2022 um 18:49 schrieb Mark Rivers <rivers at cars.uchicago.edu>:
> This could be a firewall issue.  Did you try temporarily turning off the Windows firewall?  It could be that caget has a firewall exception in place but Python does not.
> Mark
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Thomas Feggeler via Tech-talk
> Sent: Thursday, June 9, 2022 10:29 AM
> To: tech-talk at aps.anl.gov
> Subject: PyEpics: Cannot connect to DEVICE
> Dear colleagues,
> We have a new computer installation (Windows 10) with epics 7.0.4, python 3.6.4. When I try to connect with caget() directly over the command line to access a device, e.g.
> Caget XXXX:XXXX:firmwarebuilddate
> It immediately works.
> When using pyepics over pycharm, or the python interpreter, the message „cannot connect to DEVICE“ is given out.
> The Windows path variables are set, EPICS_CA_ADDR_LIST is set and imported into the pycharm environment.
> In both pycharm and python console if I do the following:
> import epics
> import os
> from epics import PV, caget, caput, cainfo os.environ['EPICS_CA_ADDR_LIST'] = 'XXX.XXX.XXX.XXX'
> os.environ['EPICS_CA_AUTO_ADDR_LIST'] = 'NO'
> print(caget('XXXX:XXXX:firmwarebuilddate'))
> The same error occurs.
> I’d kindly ask for your help.
> Thank you
> Kind wishes
> Thomas
PyEpics: Cannot connect to DEVICE Thomas Feggeler via Tech-talk
RE: PyEpics: Cannot connect to DEVICE Mark Rivers via Tech-talk
Prev: RE: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: Re: Phoebus alarm does not honor filter Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: RE: PyEpics: Cannot connect to DEVICE Mark Rivers via Tech-talk
Next: Re: PyEpics: Cannot connect to DEVICE Matt Newville via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
