1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: "Hartman, Steven via Tech-talk" <[email protected]>
Date: Thu, 9 Jun 2022 21:23:16 +0000
I was just about to reply to your other email about sensitivity to minor changes. That implies a race condition, but it is not obvious where that could be occurring.
But the difference between the A16 and A32 access errors seems important (as is the fact that in some configurations you can get either). The ISR associated with the A16 access is interesting in thinking about race conditions.
Bizarre.
Steven Hartman
[email protected]
On Jun 9, 2022, at 5:06 PM, Mark Rivers <[email protected]> wrote:
The A16 addresses are always at the in the “mailbox register” address range of the IP330 Industry Pack module in the crate.  They only happen when the IP330 module is being used.  Its interrupt service routine reads the contents  of those mailbox registers.  So those are real recently used addresses.  Those addresses are readable, but not writeable.  It seems that the bus error is arising because that address is being written.
Sent: Thursday, June 9, 2022 3:58 PM
Cc: [email protected]
Looking for an example with A16 access, I only found one, embedded in the first email of the thread . . .
[Wed May 18 20:23:06 2022] VME Bus Error accessing A16: 0x300e
[Wed May 18 20:23:06 2022] 0x55d8aa0 (CAS-event): The task has been terminated because it triggered an exception that raised the signal 10.
ioc13ida> tt 0x55d8aa0
fr0    =       -1
No obvious relation between -1.0 and 0xfbff300e, though. For the A32 access errors, the FR0 value appears to always match the bad address.
Steven Hartman
[email protected]
On Jun 9, 2022, at 1:56 PM, Hartman, Steven via Tech-talk <[email protected]> wrote:
On Jun 9, 2022, at 12:05 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
I am now convinced that the A32 addresses which generate VME bus errs are in fact the double values that are written to the ao records.
And this number shows up in the floating point register for the terminated task as FR0 . . .
VME Bus Error accessing A32: 0xbfe26ed0
fr0    = -0.576028
0xbfe26ed000000000 = -5.7602691650390620e-1
VME Bus Error accessing A32: 0xbffffffc
fr0    =       -2
0xbffffffc00000000 = -1.9999961853027344
Still the big question as to where this is being treated as an address.
Steven Hartman
[email protected]
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Hartman, Steven via Tech-talk
RE: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Prev: RE: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
