1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: StreamDevice with a REST API
From: "Zimoch Dirk \(PSI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "christopher.gregory at stfc.ac.uk" <christopher.gregory at stfc.ac.uk>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 10 Jun 2022 13:27:57 +0000
Hi Chris
I did something similar here:
https://paulscherrerinstitute.github.io/StreamDevice/tipsandtricks.html#web
At a first glance, all you did looks just fine.
As the host is running on Windows, do you need CR LF CR LF? (I hope not.)
I am testing now now one of our REST APIs....
Dirk
On Fri, 2022-06-10 at 13:10 +0000, Chris Gregory - STFC UKRI via Tech-talk wrote:
> I'm writing an IOC for a device that has a REST API. Replies are simple and predictable so I'm hoping that I won't
> need anything more complex than StreamDevice.
> At the moment I can't get a reply from the device. In my dev setup I'm running the IOC under WSL2, with the device
> software running on the Windows host on port 8001. The port is open in the firewall. Would anyone have any pointers
> please? (I've subbed my real Windows host ip address with <my_ip_address> in the below but in the application I've got
> the full address written out.)
> Protocol:
> 	read_variable{
> 	  outTerminator = LF LF;
> 	  replyTimeout = 5000;
> 	  out "GET http://<my_ip_address>:8001/REST/HTTP_CMD/?RDVAR/State HTTP/1.1";
> 	  in "%#s";
> Record:
> 	record (stringin, "RDV_TEST") {
>  	  field(DTYP, "stream")
>   	  field(INP, "@eksplaAPL038.proto read_variable() $(PORT)")
>  	  field(SCAN, "5 second")
> PORT configuration in st.cmd:
> 	drvAsynIPPortConfigure("$(PORT)", "<my_ip_address>:8001 HTTP",0,0,0)
> When I run the IOC the asynTraceMask shows that I'm sending what I expect, but I don't get any reply. E.g.
> 	epics> 2022/06/10 13:40:59.703 <my_ip_address>:8001 HTTP write 67
> 	GET http://<my_ip_address>:8001/REST/HTTP_CMD/?RDVAR/State HTTP/1.1\n\n
> Using telnet from WSL2 with the same ip:port the following both succeed and get the expected reply from the device:
> 	or
> 	GET /REST/HTTP_CMD/?RDVAR/State HTTP/1.1
> I've tried the following "out" commands in the protocol file. No reply in any case:
> 	out "GET http://<my_ip_address>:8001/REST/HTTP_CMD/?RDVAR/State";
> 	out "GET /REST/HTTP_CMD/?RDVAR/State HTTP/1.1";
> 	out "GET /REST/HTTP_CMD/?RDVAR/State";
> I'd be grateful for any help,
> Chris
> This email and any attachments are intended solely for the use of the named recipients. If you are not the intended
> recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the
> sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every
> reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the
> recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: StreamDevice with a REST API Kasemir, Kay via Tech-talk
StreamDevice with a REST API Chris Gregory - STFC UKRI via Tech-talk
Prev: StreamDevice with a REST API Chris Gregory - STFC UKRI via Tech-talk
Next: RE: StreamDevice with a REST API Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: StreamDevice with a REST API Kasemir, Kay via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
