1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: StreamDevice with a REST API
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "christopher.gregory at stfc.ac.uk" <christopher.gregory at stfc.ac.uk>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Date: Fri, 10 Jun 2022 13:32:15 +0000
> As the host is running on Windows, do you need CR LF CR LF? (I hope not.)
CR = <US-ASCII CR, carriage return (13)>
LF = <US-ASCII LF, linefeed (10)>
HTTP/1.1 defines the sequence CR LF as the end-of-line marker for all protocol elements except the entity-body
And you need two of them at the end of GET:
  1. Ends the GET
  2. Tells the server that there are no more request headers
RE: StreamDevice with a REST API Chris Gregory - STFC UKRI via Tech-talk
Re: StreamDevice with a REST API Zimoch Dirk (PSI) via Tech-talk
Prev: RE: StreamDevice with a REST API Freddie Akeroyd - STFC UKRI via Tech-talk
Next: RE: StreamDevice with a REST API Chris Gregory - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: StreamDevice with a REST API Zimoch Dirk (PSI) via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
