Thanks both,
Just tested and I confirm that outTerminator = CR LF CR LF works for me.
Regards
Chris
Sent: 10 June 2022 14:32
To: Gregory, Chris (STFC,RAL,CLF) <christopher.gregory at stfc.ac.uk>; tech-talk at aps.anl.gov; Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>
Subject: Re: StreamDevice with a REST API
> As the host is running on Windows, do you need CR LF CR LF? (I hope not.)
CR = <US-ASCII CR, carriage return (13)>
LF = <US-ASCII LF, linefeed (10)>
HTTP/1.1 defines the sequence CR LF as the end-of-line marker for all protocol elements except the entity-body
And you need two of them at the end of GET:
Ends the GET
Tells the server that there are no more request headers
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
- Re: StreamDevice with a REST API Zimoch Dirk (PSI) via Tech-talk
- StreamDevice with a REST API Chris Gregory - STFC UKRI via Tech-talk
- Re: StreamDevice with a REST API Kasemir, Kay via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
