1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: ADCore build error
From: "Heesterman, Peter J via Tech-talk" <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 15 Jun 2022 15:35:32 +0000
Hi John,
I believe you’re going to need a later version of Asyn.
The release notes say that 64-bit integer support was added with R4-37.
Cheers,
Peter.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of John Dobbins via Tech-talk
Sent: 15 June 2022 16:25
To: tech-talk at aps.anl.gov
Subject: ADCore build error
I just cloned areaDetector, ADCore, ADSupport, ADEiger.
Using base 7.0.3 , asyn-R4-36 I get the following error:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DBUILDING_ADCore_API   -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/homes/det/epics/synApps_6_1/support/asyn-R4-36/include     -I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADSupport/include/os/Linux -I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADSupport/include   -I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADCore/include -I/homes/det/epics/base-7.0.3/include/compiler/gcc -I/homes/det/epics/base-7.0.3/include/os/Linux -I/homes/det/epics/base-7.0.3/include        -c ../paramAttribute.cpp
../paramAttribute.cpp: In member function 'virtual int paramAttribute::updateValue()':
../paramAttribute.cpp:138:37: error: 'class asynNDArrayDriver' has no member named 'getInteger64Param'
             status = this->pDriver->getInteger64Param(this->paramAddr, this->paramId,
Advice?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADCore build error John Dobbins via Tech-talk
Prev: ADCore build error John Dobbins via Tech-talk
Next: RE: ADCore build error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
