Ø
I just cloned areaDetector, ADCore, ADSupport, ADEiger.
I assume that means you are running the master branch of those modules?
If so, the release notes for ADCore R3-8 from October 2019 say that asyn R4-37 is required because it needs that asynInt64 support.
On Behalf Of John Dobbins via Tech-talk
Sent: Wednesday, June 15, 2022 10:25 AM
To: tech-talk at aps.anl.gov
Subject: ADCore build error
Using base 7.0.3 , asyn-R4-36 I get the following error:
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DBUILDING_ADCore_API -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common
-I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/homes/det/epics/synApps_6_1/support/asyn-R4-36/include -I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADSupport/include/os/Linux -I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADSupport/include
-I/homes/det/epics/synApps_6_1/support/areaDetector-R3-12-1/ADCore/include -I/homes/det/epics/base-7.0.3/include/compiler/gcc -I/homes/det/epics/base-7.0.3/include/os/Linux -I/homes/det/epics/base-7.0.3/include -c ../paramAttribute.cpp
../paramAttribute.cpp: In member function 'virtual int paramAttribute::updateValue()':
../paramAttribute.cpp:138:37: error: 'class asynNDArrayDriver' has no member named 'getInteger64Param'
status = this->pDriver->getInteger64Param(this->paramAddr, this->paramId,
Research Support Specialist
Cornell High Energy Synchrotron Source
- ADCore build error John Dobbins via Tech-talk
RE: ADCore build error Heesterman, Peter J via Tech-talk
ADEiger R3-4 EIGER1 param=high_voltage/state John Dobbins via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
