1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Some Questions With RTEMS 5 in MVME2502
From: chengsn via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 16 Jun 2022 18:14:14 +0800 (GMT+08:00)
Sorry, I got something wrong, the EPICS 7 version I used was downloaded from github, and just now I re-tryed the base-7.0.6.1 version: $ wget https://epics.anl.gov/download/base/base-7.0.6.1.tar.gz.
Then, I ran the exampleApp :
***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
***** Ask ntp server once... *****
time from ntp : 06/16/22 09:59:35.000001019 UTC
***** Setting up file system *****
***** Initializing NFS *****
nfsMount("10.1.201.31", "/tftpboot", "/tftpboot")
Mount 10.1.201.31:/tftpboot on /tftpboot
 check for time registered , C++ initialization ...
***** Preparing EPICS application *****
chdir("/tftpboot/mv2500/")
***** Starting EPICS application *****
#< envPaths
dbLoadDatabase("dbd/test.dbd")
test_registerRecordDeviceDriver(pdbbase)
## Load record instances
dbLoadTemplate("db/user.substitutions")
dbLoadRecords("db/testVersion.db", "user=chengsn")
dbLoadRecords("db/dbSubExample.db", "user=chengsn")
#var mySubDebug 1
#traceIocInit
iocInit
Starting iocInit
## EPICS R7.0.6.1
## Rev. 2022-06-16T17:52+0800
## Start any sequence programs
#seq(sncExample, "user=chengsn")
***** Primary Network interface : tsec0 *****
all out ---> interface = tsec2
all out ---> reason = IPV4LL
all out ---> pid = 1
all out ---> ifmetric = 203
all out ---> ifwireless = 0
all out ---> ifflags = 4294936643
all out ---> ifmtu = 1500
all out ---> interface_order = tsec0 tsec2 tsec1
all out ---> if_up = true
all out ---> if_down = false
all out ---> new_ip_address = 169.254.57.184
all out ---> new_subnet_cidr = 16
all out ---> new_network_number = 169.254.0.0
all out ---> new_subnet_mask = 255.255.0.0
all out ---> new_broadcast_address = 169.254.255.255
all out ---> interface = tsec0
all out ---> reason = RENEW
all out ---> ifmetric = 201
all out ---> old_ip_address = 10.1.201.13
all out ---> old_subnet_cidr = 24
all out ---> old_broadcast_address = 10.1.201.255
all out ---> old_network_number = 10.1.201.0
all out ---> old_server_name = 10.1.201.31
all out ---> old_subnet_mask = 255.255.255.0
all out ---> old_routers = 10.1.201.1
all out ---> old_dhcp_lease_time = 600
all out ---> old_dhcp_message_type = 5
all out ---> old_dhcp_server_identifier = 10.1.201.31
all out ---> old_dhcp_renewal_time = 300
all out ---> old_dhcp_rebinding_time = 525
all out ---> new_ip_address = 10.1.201.13
all out ---> new_subnet_cidr = 24
all out ---> new_broadcast_address = 10.1.201.255
all out ---> new_network_number = 10.1.201.0
all out ---> new_server_name = 10.1.201.31
all out ---> new_subnet_mask = 255.255.255.0
all out ---> new_routers = 10.1.201.1
all out ---> new_dhcp_lease_time = 600
all out ---> new_dhcp_message_type = 5
all out ---> new_dhcp_server_identifier = 10.1.201.31
all out ---> new_dhcp_renewal_time = 300
all out ---> new_dhcp_rebinding_time = 525
But I cannot input anything in the shell.
Is this normal?
-----原始邮件-----
发件人:chengsn at ihep.ac.cn
发送时间:2022-06-16 17:14:33 (星期四)
收件人: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
抄送:
主题: Some Questions With RTEMS 5 in MVME2502
Hello All,
  I followed the steps at EPICS with RTEMS, compiled RTEMS 5, and ran an example hello on MVME2502. The dtb file was generated from the linux source file: dtc -I dts -O dtb linux/arch/powerpc/boot/dts/fsl/mvme2500.dts -o mvme2500.dtb
  If I didn't change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file test.c, the OUTPUT is:
Bytes transferred = 12331 (302b hex)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   hello
   Created:      2022-06-09   15:06:14 UTC
   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
   Data Size:    51612 Bytes = 50.4 KiB
   Load Address: 00004000
   Entry Point:  00004000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 00c00000
   Booting using the fdt blob at 0xc00000
   Uncompressing Kernel Image ... OK
ft_fixup_l2cache: FDT_ERR_NOTFOUND
?H?@?LR???r????I?C?=GC?c?
 Then, I compiled EPICS base 7.0.6.1, made a EPICS exampleApp test, ran the image file bin/RTEMS-qoriq_e500/test.img. The OUTPUT is:
   Image Name:   test
   Created:      2022-06-08  16:51:21 UTC
   Data Size:    2734725 Bytes = 2.6 MiB
?C???)???G?}[k???C8V?o?????????????k???J?G&k)?J?gb!?CruB??????g?s ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=????????1b?R?W?jR?C?b???c?????gb
So, I had to change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file base/modules/libcom/RTEMS/posix/rtems_config.c.
Did I do something wrong?
  After recompiling EPICS and making the exampleApp, the IOC started to get the ip through DHCP. I set some file paths in the rtems_init.c file, but there was some other information after the IOC initialization was completed:
diff --git a/modules/libcom/RTEMS/posix/rtems_init.c b/modules/libcom/RTEMS/posix/rtems_init.c
index 403cd0785..d7886b6ab 100644
--- a/modules/libcom/RTEMS/posix/rtems_init.c
+++ b/modules/libcom/RTEMS/posix/rtems_init.c
@@ -97,10 +97,10 @@ epicsEventId        dhcpDone;
  * may provide by dhcp/bootp
  * or environments from the "BIOS" like u-boot, motboot etc.
-char rtemsInit_NTP_server_ip[16] = "";
-char bootp_server_name_init[128] = "[email protected]:/epics";
-char bootp_boot_file_name_init[128] = "/epics/myExample/bin/RTEMS-beatnik/myExample.boot";
-char bootp_cmdline_init[128] = "/epics/myExample/iocBoot/iocmyExample/st.cmd";
+char rtemsInit_NTP_server_ip[16] = "10.1.201.31";
+char bootp_server_name_init[128] = "10.1.201.31:/tftpboot";
+char bootp_boot_file_name_init[128] = "/tftpboot/mv2500/bin/RTEMS-qoriq_e500/test.img";
+char bootp_cmdline_init[128] = "/tftpboot/mv2500/iocBoot/ioctest/st.cmd";
 struct in_addr rtems_bsdnet_bootp_server_address;
 /* TODO check rtems_bsdnet_bootp_cmdline */
some OUTPUT:
MVME2500=> run epicsTest
Speed: 1000, full duplex
Using eTSEC1 device
TFTP from server 10.1.201.31; our IP address is 10.1.201.125
Filename 'mv2500/bin/RTEMS-qoriq_e500/test.img'.
Load address: 0x1000000
Loading: #################################################################
done
Bytes transferred = 1997059 (1e7903 hex)
Using eTSEC1 device
Filename 'mvme2500.dtb'.
Load address: 0xc00000
Loading: #
done
   Image Name:   test
   Created:      2022-06-08  14:23:06 UTC
   Data Size:    1996995 Bytes = 1.9 MiB
WARNING: OS Clock time was read before being set.
Using 1990-01-02 00:00:00.000000 UTC
 initConsole --- Info ---
stdin: fileno: 0, ttyname: /dev/console
stdout: fileno: 1, ttyname: /dev/console
stderr: fileno: 2, ttyname: /dev/console
tcgetattr failed: Not a character device
time set to : 04/14/14 07:30:06.000000839 UTC
Startup.
epicsThreadSetPriority called by non epics thread
***** RTEMS Version: rtems-5.0.0 (PowerPC/Generic (E500/float-gprs/SPE)/qoriq_e500) *****
***** Initializing network (libbsd, dhcpcd) *****
nexus0: <RTEMS Nexus device>
ofwbus0: <Open Firmware Device Tree> on nexus0
-------------- IFCONFIG -----------------
tsec0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8000b<RXCSUM,TXCSUM,VLAN_MTU,LINKSTATE>
        ether ec:9e:cd:13:47:66
        inet6 fe80::ee9e:cdff:fe13:4766%tsec0 prefixlen 64 scopeid 0x1
        inet 10.1.201.13 netmask 0xffffff00 broadcast 10.1.201.255
        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
tsec1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether ec:9e:cd:13:47:67
        inet6 fe80::ee9e:cdff:fe13:4767%tsec1 prefixlen 64 scopeid 0x2
        media: Ethernet autoselect (none)
        status: no carrier
tsec2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=b<RXCSUM,TXCSUM,VLAN_MTU>
        ether ec:9e:cd:13:47:68
        inet6 fe80::ee9e:cdff:fe13:4768%tsec2 prefixlen 64 scopeid 0x3
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet 127.0.0.1 netmask 0xffffff00
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
        groups: lo
-------------- NETSTAT ------------------
Routing tables
Internet:
Destination        Gateway            Flags     Netif Expire
default           10.1.201.1         UGS       tsec0
10.1.201.0/24     link#1             U         tsec0
10.1.201.13        link#1             UHS         lo0
127.0.0.1         link#4             UH          lo0
Internet6:
::1                            link#4                       UH          lo0
fe80::%tsec0/64                   link#1                        U         tsec0
fe80::ee9e:cdff:fe13:4766%tsec0        link#1                        UHS         lo0
fe80::%tsec1/64                   link#2                        U         tsec1
fe80::ee9e:cdff:fe13:4767%tsec1        link#2                        UHS         lo0
fe80::%tsec2/64                   link#3                        U         tsec2
fe80::ee9e:cdff:fe13:4768%tsec2        link#3                        UHS         lo0
fe80::%lo0/64                     link#4                       U           lo0
fe80::1%lo0                      link#4                        UHS         lo0
debug: tsec0: sending ARP announce (2 of 2)
debug: tsec2: sending DISCOVER (xid 0xa096e1f), next in %0.1f seconds
time from ntp : 06/15/22 06:51:49.000000839 UTC
chdir("/tftpboot/mv2500/iocBoot/ioctest/")
#< envPaths
dbLoadDatabase("../../dbd/test.dbd")
#dbLoadTemplate("db/user.substitutions")
dbLoadRecords("../../db/testVersion.db", "user=chengsn")
dbLoadRecords("../../db/circle.db", "user=chengsn")
dbLoadRecords("../../db/dbSubExample.db", "user=chengsn")
#var mySubDebug 1
#traceIocInit
iocInit
Starting iocInit
## EPICS R7.0.6.2-DEV
## Rev. R7.0.6.1-103-g3fadf4a26cfe33dcb9eb-dirty
RTEMShost> tsec2: sending DISCOVER (xid 0xa096e1f), next in 31.1 secondstimed outallowing 8 seconds for IPv4LL timeouttsec2: probing for an IPv4LL addresstsec2: checking for 169.254.92.20tsec2: sending ARP probe (1 of 3), next in 1.6 secondstsec2: sending ARP probe (2 of 3), next in 1.7 secondstsec2: sending ARP probe (3 of 3), next in 2.0 secondstsec2: using IPv4LL address 169.254.92.20tsec2: adding IP address 169.254.92.20/16tsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec2: writing lease `/var/db/dhcpcd-tsec2.lease'tsec2: executing `ioc boot' IPV4LL
dhcpcd ---> 'interface=tsec2'
  'interface' = 'tsec2'
dhcpcd ---> 'reason=IPV4LL'
  'reason' = 'IPV4LL'
dhcpcd ---> 'pid=1'
dhcpcd ---> 'ifmetric=203'
dhcpcd ---> 'ifwireless=0'
dhcpcd ---> 'ifflags=4294936643'
dhcpcd ---> 'ifmtu=1500'
dhcpcd ---> 'interface_order=tsec0 tsec2 tsec1'
dhcpcd ---> 'if_up=true'
dhcpcd ---> 'if_down=false'
dhcpcd ---> 'new_ip_address=169.254.92.20'
dhcpcd ---> 'new_subnet_cidr=16'
dhcpcd ---> 'new_network_number=169.254.0.0'
dhcpcd ---> 'new_subnet_mask=255.255.0.0'
dhcpcd ---> 'new_broadcast_address=169.254.255.255'
tsec2: sending ARP announce (1 of 2), next in 2.0 secondstimed outtsec2: sending ARP announce (2 of 2)tsec2: soliciting a DHCP leasetsec2: sending DISCOVER (xid 0x614c417a), next in 3.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 7.3 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 15.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 32.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.9 secondstsec0: renewing lease of 10.1.201.13tsec0: rebind in 225 seconds, expire in 300 secondstsec0: sending REQUEST (xid 0x504868fd), next in 4.5 secondstsec0: acknowledged 10.1.201.13 from 10.1.201.31 `10.1.201.31'tsec0: leased 10.1.201.13 for 600 secondstsec0: renew in 300 seconds, rebind in 525 secondstsec0: IP address 10.1.201.13/24 already existstsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec0: writing lease `/var/db/dhcpcd-tsec0.lease'tsec0: executing `ioc boot' RENEW
Then, the IOC will keep restarting...
What should I do to get the IOC working properly?
Best regards,
chengsn
Re: Some Questions With RTEMS 5 in MVME2502 Heinz Junkes via Tech-talk
Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Prev: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Next: Re: ADEiger R3-4 EIGER1 param=high_voltage/state Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Some Questions With RTEMS 5 in MVME2502 Heinz Junkes via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
