1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: ADEiger R3-4 EIGER1 param=high_voltage/state
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 16 Jun 2022 13:38:16 +0000
Hi John,
I have pushed a fix to the master branch to eliminate that spurious error message about HV_STATE when creating the detector.
Note that depending on the Eiger model you may still see error messages like this when creating the detector:
RestApi::get: [param=link_2] server returned error code 500
2022/06/16 08:26:42.063 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2022/06/16 08:26:42.063 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
Those errors arise because the driver creates parameters to query the status of 4 Ethernet links on the detector.  However, some detectors have fewer than 4 links and the Dectris API does not provide a way to query the actual number of links.  For example our Eiger 500 only has 2 links, and so only links 0 and 1 exist, and I see those error messages for links 2 and 3.
These error messages can be ignored.
Sent: Wednesday, June 15, 2022 2:02 PM
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: ADEiger R3-4 EIGER1 param=high_voltage/state
Hi John,
You can ignore that message.  The driver only polls that value if it is an Eiger2, but it does create the parameter even if it is an Eiger1.  That is a mistake and I will fix it in a future release.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of John Dobbins via Tech-talk
Sent: Wednesday, June 15, 2022 1:36 PM
To: tech-talk at aps.anl.gov
Subject: ADEiger R3-4 EIGER1 param=high_voltage/state
All,
I just built ADEiger from the current Master (R3-4). When I start the EIGER1 IOC I get a message
RestApi::get: [param=high_voltage/state] server returned error code 500
2022/06/15 14:23:47.959 Param[HV_STATE]::baseFetch: [param=high_voltage/state] unable to parse json response
2022/06/15 14:23:47.959 Param[HV_STATE]::fetch<string>: [param=HV_STATE] underlying baseFetch failed
The is after eigerDetectorConfig.
According to the ADEiger/RELEASE.md  high_voltage/state is only available on EIGER2.
asyn port:         EIG
EPICS name:    EIG2:cam1:
Model:              Eiger 4M
Firmware:         eiger-1.6.6-272.gitb59a1d9.release
SDK:                   1.6.6
Driver version: 3.4.0
ADCore :            3.12.1
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADEiger R3-4 EIGER1 param=high_voltage/state John Dobbins via Tech-talk
RE: ADEiger R3-4 EIGER1 param=high_voltage/state Mark Rivers via Tech-talk
Prev: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Next: Re: Some Questions With RTEMS 5 in MVME2502 Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: RE: ADEiger R3-4 EIGER1 param=high_voltage/state Mark Rivers via Tech-talk
Next: EPICS Support for Ophir RF Amplifiers (5020 and 5064) Tang, Johnny via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
