1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Some Questions With RTEMS 5 in MVME2502
From: Heinz Junkes via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 20 Jun 2022 10:57:49 +0200
You're right, that needs to be commented out. Unfortunately, I had overlooked it.
Viele Grüße
Heinz
> On 20. Jun 2022, at 10:51, [email protected] wrote:
> Thanks for your help!
> When I try to connect to 10.1.201.13, I get "telnet: connect to address 10.1.201.13: Connection refused error". I changed another computer and tried again, still the same. But I can access the PV on 10.1.201.13 on the pc, either via caget or pvget.
> Maybe the rtems_telnetd_initialize() in rtems_init() should be run?
> Some code in the rtems_init.c:1112,
> #if __RTEMS_MAJOR__>4
>    // if telnetd is requested ...
>   // printf(" Will try to start telnetd with prio %d ...\n", rtems_telnetd_config.priority);
>   // result = rtems_telnetd_initialize();
>   // printf (" telnetd initialized with result %d\n", result);
> #endif
> Thanks!
> chengsn
>> -----Original Messages-----
>> From: "Heinz Junkes" <[email protected]>
>> Sent Time: 2022-06-17 16:04:46 (Friday)
>> Cc: "[email protected]" <[email protected]>
>> hi chengsn,
>> That doesn't look so bad. Unfortunately, I don't have an MVME2500 at the moment on which I can reproduce the whole thing.
>> I have built telnet access into the rtems_init:
>> #ifndef RTEMS_LEGACY_STACK
>> // setup own ntp-client to get time
>> /telnet
>>  char line[LINE_SIZE];
>>  int fid[3], save_fid[3];
>>  printf("info:  pty dev name = %s\n", name);
>>  save_fid[1] = dup2(1,1);
>>  fid[1] = dup2( fileno(stdout), 1);
>>  if (fid[1] == -1 ) printf("Can't dup stdout\n");
>>  save_fid[2] = dup2(2,2);
>>  fid[2] = dup2( fileno(stderr), 2);
>>  if (fid[2] == -1 ) printf("Can't dup stderr\n");
>>  const char *prompt = "tIocSh> ";
>>  while (1) {
>>    fputs(prompt, stdout);
>>    fflush(stdout);
>>    /* telnet close not detected ??? tbd */
>>    if (fgets(line, LINE_SIZE, stdin) == NULL) {
>>      dup2(save_fid[1],1);
>>      dup2(save_fid[2],2);
>>      return;
>>    if (line[strlen(line)-1] == '\n') line[strlen(line)-1] = 0;
>>    if (!strncmp( line, "bye",3)) {
>>      printf( "%s", "Will end session\n");
>>      return;
>>     iocshCmd(line);
>> You could try connecting to the system with "telnet 10.1.201.13" and you
>> should then be in an EPICS shell.
>> To exit, type "bye" (not CTRL-], otherwise the shell is blocked).
>> Viele Grüße
>> Heinz Junkes
>> Experience directly varies with equipment ruined.
>>> On 16. Jun 2022, at 12:14, chengsn via Tech-talk <[email protected]> wrote:
>>> Sorry, I got something wrong, the EPICS 7 version I used was downloaded from github, and just now I re-tryed the base-7.0.6.1 version: $ wget https://epics.anl.gov/download/base/base-7.0.6.1.tar.gz.
>>> Then, I ran the exampleApp :
>>> ***** Until now no NTP support in RTEMS 5 with rtems-libbsd *****
>>> ***** Ask ntp server once... *****
>>> time from ntp : 06/16/22 09:59:35.000001019 UTC
>>> ***** Setting up file system *****
>>> ***** Initializing NFS *****
>>> nfsMount("10.1.201.31", "/tftpboot", "/tftpboot")
>>> Mount 10.1.201.31:/tftpboot on /tftpboot
>>> check for time registered , C++ initialization ...
>>> ***** Preparing EPICS application *****
>>> chdir("/tftpboot/mv2500/")
>>> ***** Starting EPICS application *****
>>> #< envPaths
>>> ## Register all support components
>>> dbLoadDatabase("dbd/test.dbd")
>>> test_registerRecordDeviceDriver(pdbbase)
>>> ## Load record instances
>>> dbLoadTemplate("db/user.substitutions")
>>> dbLoadRecords("db/testVersion.db", "user=chengsn")
>>> dbLoadRecords("db/dbSubExample.db", "user=chengsn")
>>> #var mySubDebug 1
>>> #traceIocInit
>>> iocInit
>>> Starting iocInit
>>> ## EPICS R7.0.6.1
>>> ## Rev. 2022-06-16T17:52+0800
>>> iocRun: All initialization complete
>>> ## Start any sequence programs
>>> #seq(sncExample, "user=chengsn")
>>> ***** Primary Network interface : tsec0 *****
>>> all out ---> interface = tsec2
>>> all out ---> reason = IPV4LL
>>> all out ---> pid = 1
>>> all out ---> ifmetric = 203
>>> all out ---> ifwireless = 0
>>> all out ---> ifflags = 4294936643
>>> all out ---> ifmtu = 1500
>>> all out ---> interface_order = tsec0 tsec2 tsec1
>>> all out ---> if_up = true
>>> all out ---> if_down = false
>>> all out ---> new_ip_address = 169.254.57.184
>>> all out ---> new_subnet_cidr = 16
>>> all out ---> new_network_number = 169.254.0.0
>>> all out ---> new_subnet_mask = 255.255.0.0
>>> all out ---> new_broadcast_address = 169.254.255.255
>>> all out ---> interface = tsec0
>>> all out ---> reason = RENEW
>>> all out ---> ifmetric = 201
>>> all out ---> old_ip_address = 10.1.201.13
>>> all out ---> old_subnet_cidr = 24
>>> all out ---> old_broadcast_address = 10.1.201.255
>>> all out ---> old_network_number = 10.1.201.0
>>> all out ---> old_server_name = 10.1.201.31
>>> all out ---> old_subnet_mask = 255.255.255.0
>>> all out ---> old_routers = 10.1.201.1
>>> all out ---> old_dhcp_lease_time = 600
>>> all out ---> old_dhcp_message_type = 5
>>> all out ---> old_dhcp_server_identifier = 10.1.201.31
>>> all out ---> old_dhcp_renewal_time = 300
>>> all out ---> old_dhcp_rebinding_time = 525
>>> all out ---> new_ip_address = 10.1.201.13
>>> all out ---> new_subnet_cidr = 24
>>> all out ---> new_broadcast_address = 10.1.201.255
>>> all out ---> new_network_number = 10.1.201.0
>>> all out ---> new_server_name = 10.1.201.31
>>> all out ---> new_subnet_mask = 255.255.255.0
>>> all out ---> new_routers = 10.1.201.1
>>> all out ---> new_dhcp_lease_time = 600
>>> all out ---> new_dhcp_message_type = 5
>>> all out ---> new_dhcp_server_identifier = 10.1.201.31
>>> all out ---> new_dhcp_renewal_time = 300
>>> all out ---> new_dhcp_rebinding_time = 525
>>> But I cannot input anything in the shell.
>>> Is this normal?
>>> -----原始邮件-----
>>> 发件人:[email protected]
>>> 发送时间:2022-06-16 17:14:33 (星期四)
>>> 收件人: "[email protected]" <[email protected]>
>>> 抄送:
>>> 主题: Some Questions With RTEMS 5 in MVME2502
>>> Hello All,
>>>  I followed the steps at EPICS with RTEMS, compiled RTEMS 5, and ran an example hello on MVME2502. The dtb file was generated from the linux source file: $ dtc -I dts -O dtb linux/arch/powerpc/boot/dts/fsl/mvme2500.dts -o mvme2500.dtb
>>>  If I didn't change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file test.c, the OUTPUT is:
>>> Bytes transferred = 12331 (302b hex)
>>> WARNING: adjusting available memory to 30000000
>>> ## Booting kernel from Legacy Image at 01000000 ...
>>>   Image Name:   hello
>>>   Created:      2022-06-09   15:06:14 UTC
>>>   Image Type:   PowerPC Linux Kernel Image (gzip compressed)
>>>   Data Size:    51612 Bytes = 50.4 KiB
>>>   Load Address: 00004000
>>>   Entry Point:  00004000
>>>   Verifying Checksum ... OK
>>> ## Flattened Device Tree blob at 00c00000
>>>   Booting using the fdt blob at 0xc00000
>>>   Uncompressing Kernel Image ... OK
>>> ft_fixup_l2cache: FDT_ERR_NOTFOUND
>>> ?H?@?LR???r????I?C?=GC?c?
>>> Then, I compiled EPICS base 7.0.6.1, made a EPICS exampleApp test, ran the image file bin/RTEMS-qoriq_e500/test.img. The OUTPUT is:
>>>   Image Name:   test
>>>   Created:      2022-06-08  16:51:21 UTC
>>>   Data Size:    2734725 Bytes = 2.6 MiB
>>> ?C???)???G?}[k???C8V?o?????????????k???J?G&k)?J?gb!?CruB??????g?s ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=?????????C1H?cbjR?C?b???c??=???????? ?C1H?cbjR?C?b???c??=????????1b?R?W?jR?C?b???c?????gb
>>> So, I had to change the macro definition #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER to #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER in the file base/modules/libcom/RTEMS/posix/rtems_config.c.
>>> Did I do something wrong?
>>>  After recompiling EPICS and making the exampleApp, the IOC started to get the ip through DHCP. I set some file paths in the rtems_init.c file, but there was some other information after the IOC initialization was completed:
>>> diff --git a/modules/libcom/RTEMS/posix/rtems_init.c b/modules/libcom/RTEMS/posix/rtems_init.c
>>> index 403cd0785..d7886b6ab 100644
>>> --- a/modules/libcom/RTEMS/posix/rtems_init.c
>>> +++ b/modules/libcom/RTEMS/posix/rtems_init.c
>>> @@ -97,10 +97,10 @@ epicsEventId        dhcpDone;
>>>  * may provide by dhcp/bootp
>>>  * or environments from the "BIOS" like u-boot, motboot etc.
>>> -char rtemsInit_NTP_server_ip[16] = "";
>>> -char bootp_server_name_init[128] = "[email protected]:/epics";
>>> -char bootp_boot_file_name_init[128] = "/epics/myExample/bin/RTEMS-beatnik/myExample.boot";
>>> -char bootp_cmdline_init[128] = "/epics/myExample/iocBoot/iocmyExample/st.cmd";
>>> +char rtemsInit_NTP_server_ip[16] = "10.1.201.31";
>>> +char bootp_server_name_init[128] = "10.1.201.31:/tftpboot";
>>> +char bootp_boot_file_name_init[128] = "/tftpboot/mv2500/bin/RTEMS-qoriq_e500/test.img";
>>> +char bootp_cmdline_init[128] = "/tftpboot/mv2500/iocBoot/ioctest/st.cmd";
>>> struct in_addr rtems_bsdnet_bootp_server_address;
>>> /* TODO check rtems_bsdnet_bootp_cmdline */
>>> some OUTPUT:
>>> MVME2500=> run epicsTest
>>> Speed: 1000, full duplex
>>> Using eTSEC1 device
>>> TFTP from server 10.1.201.31; our IP address is 10.1.201.125
>>> Filename 'mv2500/bin/RTEMS-qoriq_e500/test.img'.
>>> Load address: 0x1000000
>>> Loading: #################################################################
>>> done
>>> Bytes transferred = 1997059 (1e7903 hex)
>>> Using eTSEC1 device
>>> Filename 'mvme2500.dtb'.
>>> Load address: 0xc00000
>>> Loading: #
>>> done
>>>   Image Name:   test
>>>   Created:      2022-06-08  14:23:06 UTC
>>>   Data Size:    1996995 Bytes = 1.9 MiB
>>> WARNING: OS Clock time was read before being set.
>>> Using 1990-01-02 00:00:00.000000 UTC
>>> initConsole --- Info ---
>>> stdin: fileno: 0, ttyname: /dev/console
>>> stdout: fileno: 1, ttyname: /dev/console
>>> stderr: fileno: 2, ttyname: /dev/console
>>> tcgetattr failed: Not a character device
>>> time set to : 04/14/14 07:30:06.000000839 UTC
>>> Startup.
>>> epicsThreadSetPriority called by non epics thread
>>> ***** RTEMS Version: rtems-5.0.0 (PowerPC/Generic (E500/float-gprs/SPE)/qoriq_e500) *****
>>> ***** Initializing network (libbsd, dhcpcd) *****
>>> nexus0: <RTEMS Nexus device>
>>> ofwbus0: <Open Firmware Device Tree> on nexus0
>>> -------------- IFCONFIG -----------------
>>> tsec0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>>>        options=8000b<RXCSUM,TXCSUM,VLAN_MTU,LINKSTATE>
>>>        ether ec:9e:cd:13:47:66
>>>        inet6 fe80::ee9e:cdff:fe13:4766%tsec0 prefixlen 64 scopeid 0x1
>>>        inet 10.1.201.13 netmask 0xffffff00 broadcast 10.1.201.255
>>>        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
>>>        media: Ethernet autoselect (1000baseT <full-duplex>)
>>>        status: active
>>> tsec1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>>>        ether ec:9e:cd:13:47:67
>>>        inet6 fe80::ee9e:cdff:fe13:4767%tsec1 prefixlen 64 scopeid 0x2
>>>        media: Ethernet autoselect (none)
>>>        status: no carrier
>>> tsec2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
>>>        options=b<RXCSUM,TXCSUM,VLAN_MTU>
>>>        ether ec:9e:cd:13:47:68
>>>        inet6 fe80::ee9e:cdff:fe13:4768%tsec2 prefixlen 64 scopeid 0x3
>>> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
>>>        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
>>>        inet 127.0.0.1 netmask 0xffffff00
>>>        inet6 ::1 prefixlen 128
>>>        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
>>>        groups: lo
>>> -------------- NETSTAT ------------------
>>> Routing tables
>>> Internet:
>>> Destination        Gateway            Flags     Netif Expire
>>> default           10.1.201.1         UGS       tsec0
>>> 10.1.201.0/24     link#1             U         tsec0
>>> 10.1.201.13        link#1             UHS         lo0
>>> 127.0.0.1         link#4             UH          lo0
>>> Internet6:
>>> ::1                            link#4                       UH          lo0
>>> fe80::%tsec0/64                   link#1                        U         tsec0
>>> fe80::ee9e:cdff:fe13:4766%tsec0        link#1                        UHS         lo0
>>> fe80::%tsec1/64                   link#2                        U         tsec1
>>> fe80::ee9e:cdff:fe13:4767%tsec1        link#2                        UHS         lo0
>>> fe80::%tsec2/64                   link#3                        U         tsec2
>>> fe80::ee9e:cdff:fe13:4768%tsec2        link#3                        UHS         lo0
>>> fe80::%lo0/64                     link#4                       U           lo0
>>> fe80::1%lo0                      link#4                        UHS         lo0
>>> debug: tsec0: sending ARP announce (2 of 2)
>>> debug: tsec2: sending DISCOVER (xid 0xa096e1f), next in %0.1f seconds
>>> time from ntp : 06/15/22 06:51:49.000000839 UTC
>>> chdir("/tftpboot/mv2500/iocBoot/ioctest/")
>>> #< envPaths
>>> dbLoadDatabase("../../dbd/test.dbd")
>>> #dbLoadTemplate("db/user.substitutions")
>>> dbLoadRecords("../../db/testVersion.db", "user=chengsn")
>>> dbLoadRecords("../../db/circle.db", "user=chengsn")
>>> dbLoadRecords("../../db/dbSubExample.db", "user=chengsn")
>>> #var mySubDebug 1
>>> #traceIocInit
>>> iocInit
>>> Starting iocInit
>>> ## EPICS R7.0.6.2-DEV
>>> ## Rev. R7.0.6.1-103-g3fadf4a26cfe33dcb9eb-dirty
>>> RTEMShost> tsec2: sending DISCOVER (xid 0xa096e1f), next in 31.1 secondstimed outallowing 8 seconds for IPv4LL timeouttsec2: probing for an IPv4LL addresstsec2: checking for 169.254.92.20tsec2: sending ARP probe (1 of 3), next in 1.6 secondstsec2: sending ARP probe (2 of 3), next in 1.7 secondstsec2: sending ARP probe (3 of 3), next in 2.0 secondstsec2: using IPv4LL address 169.254.92.20tsec2: adding IP address 169.254.92.20/16tsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec2: writing lease `/var/db/dhcpcd-tsec2.lease'tsec2: executing `ioc boot' IPV4LL
>>> dhcpcd ---> 'interface=tsec2'
>>>  'interface' = 'tsec2'
>>> dhcpcd ---> 'reason=IPV4LL'
>>>  'reason' = 'IPV4LL'
>>> dhcpcd ---> 'pid=1'
>>> dhcpcd ---> 'ifmetric=203'
>>> dhcpcd ---> 'ifwireless=0'
>>> dhcpcd ---> 'ifflags=4294936643'
>>> dhcpcd ---> 'ifmtu=1500'
>>> dhcpcd ---> 'interface_order=tsec0 tsec2 tsec1'
>>> dhcpcd ---> 'if_up=true'
>>> dhcpcd ---> 'if_down=false'
>>> dhcpcd ---> 'new_ip_address=169.254.92.20'
>>> dhcpcd ---> 'new_subnet_cidr=16'
>>> dhcpcd ---> 'new_network_number=169.254.0.0'
>>> dhcpcd ---> 'new_subnet_mask=255.255.0.0'
>>> dhcpcd ---> 'new_broadcast_address=169.254.255.255'
>>> tsec2: sending ARP announce (1 of 2), next in 2.0 secondstimed outtsec2: sending ARP announce (2 of 2)tsec2: soliciting a DHCP leasetsec2: sending DISCOVER (xid 0x614c417a), next in 3.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 7.3 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 15.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 32.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.5 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.6 secondstsec2: sending DISCOVER (xid 0x614c417a), next in 63.9 secondstsec0: renewing lease of 10.1.201.13tsec0: rebind in 225 seconds, expire in 300 secondstsec0: sending REQUEST (xid 0x504868fd), next in 4.5 secondstsec0: acknowledged 10.1.201.13 from 10.1.201.31 `10.1.201.31'tsec0: leased 10.1.201.13 for 600 secondstsec0: renew in 300 seconds, rebind in 525 secondstsec0: IP address 10.1.201.13/24 already existstsec0: adding host route to 10.1.201.13 via 127.0.0.1tsec0: ipv4_addroute: mtsec0: adding route to 10.1.201.0/24tsec0: ipv4_addroute: mtsec2: adding host route to 169.254.92.20 via 127.0.0.1tsec2: ipv4_addroute: mtsec2: adding route to 169.254.0.0/16tsec2: ipv4_addroute: mtsec0: writing lease `/var/db/dhcpcd-tsec0.lease'tsec0: executing `ioc boot' RENEW
>>> Then, the IOC will keep restarting...
>>> What should I do to get the IOC working properly?
>>> Best regards,
>>> chengsn
Re: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Re: Some Questions With RTEMS 5 in MVME2502 Heinz Junkes via Tech-talk
Prev: Re: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Next: Re: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
