1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: MATLAB and LabCA
From: "Larregui, Julian via Tech-talk" <[email protected]>
Date: Mon, 20 Jun 2022 22:11:41 +0000
Hello,
Currently trying to install LabCA 3.8 with MATLAB 2022a.
I've set my my paths in the Release file:
MATLABDIR=C:\EPICS_MATLAB\MATLAB\R2022a
and
MATLIB_SUBDIR=C:\EPICS_MATLAB\MATLAB\R2022a\extern\lib\win64\mingw64
When I run make I get the following error:
EPICS/epics-base/include/compiler/gcc -I/home/larregui1-linux/EPICS/epics-base/include/os/Linux -I/home/larregui1-linux/EPICS/epics-base/include              -I../../ezca -IC:\EPICS_MATLAB\MATLAB\R2022a/extern/include    -c gitstring.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DMATLAB_APP    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration     -g  -mtune=generic      -m64 -fPIC  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/home/larregui1-linux/EPICS/epics-base/include/compiler/gcc -I/home/larregui1-linux/EPICS/epics-base/include/os/Linux -I/home/larregui1-linux/EPICS/epics-base/include              -I../../ezca -IC:\EPICS_MATLAB\MATLAB\R2022a/extern/include    -c ../mglue.c
make[2]: *** No rule to make target '../../lib/linux-x86_64/libmx.a', needed by 'libmezcaglue.so.0'.  Stop.
make[2]: Leaving directory '/home/larregui1-linux/EPICS/support/epics-labca-master/glue/O.linux-x86_64'
/home/larregui1-linux/EPICS/epics-base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/larregui1-linux/EPICS/support/epics-labca-master/glue'
/home/larregui1-linux/EPICS/epics-base/configure/RULES_DIRS:85: recipe for target 'glue.install' failed
make: *** [glue.install] Error 2
I wanted to know if anyone had this same issue. Is this from incorrectly configuring the Release file? Anything I can try to get around this?
I guess I can also try installing 2020b or 2020a versions of MATLAB and see if that works.
Thank you for your time,
Re: MATLAB and LabCA Till Straumann via Tech-talk
Prev: Re: Some Questions With RTEMS 5 in MVME2502 Heinz Junkes via Tech-talk
Next: Re: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Digitizers Roehrig, Christian via Tech-talk
Next: Re: MATLAB and LabCA Till Straumann via Tech-talk
