1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: [EXTERNAL] Re: PVA monitor request parameters
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 22 Jun 2022 21:03:53 +0000
Hi Michael,
	> I’m seeing poor performance using the default PV request type on the receive side:
	Could you quantify what "poor performance" means?  Are you only looking at dropped updates?  Do you	 have any observations wrt. CPU and/or network load?
Yes, apologies, I think I rushed the e-mail. I'm currently running a script and doing more detailed tests so I'll be able to give a lot more details in a few days.
This is using base 7.0.6.1.
The VM is fairly underpowered and only has 2 cores allocated to it, and several other applications are running on it, although the CPU is relatively idle and less than 20% used. I was generating 0.5MB sized images at 100Hz, so about 50MB/s. Since both IOCs are running on the same VM this is going over the loopback interface.
I see dropped images (a few %) by generating a fixed number of images on the 'source' side and then comparing how many were received on the other side.
I suspect since the VM has other applications running, the IOC is sometimes suspended to allow the other programs to run, and it can't resume quick enough within the necessary 0.02 seconds (which would be the time length of the buffer if the queueSize=2). However, I did check the 'nonvoluntary_ctxt_switches' and that wasn't increasing.
	fyi. without "pipeline=true" there is no guarantee that clients won't drop updates.  So unrelated changes to 	system and/or network load may change things.
That makes sense. As well as queueSize=100 I will run the detailed testing for pipeline=true, and I'll report back.
	Yes, absolutely.  With "pipeline=true", queueSize sets the flow control window size, which is analogous to 	the TCP window size, though applied to individual subscriptions.
If pipeline=true, and queueSize sets the flow control window size on the server, does the client side buffer size remain at 2 or is it also set to queueSize?
	> I saw strange results with the “record[queueSize=100, pipeline=true]field()” where I was sending data at 	1Hz but receiving at 100Hz or so.
	Do you subscribe to a PV post()ing updates at 1Hz and somehow get 99 extra updates?
That's what it seemed like, but I'd like to do more detailed testing next.
Thanks for the detailed explanation. I'll continue testing and report back, and I'd also like to test on a more powerful machine.
Cheers,
Matt
RE: [EXTERNAL] Re: PVA monitor request parameters Pearson, Matthew via Tech-talk
Re: PVA monitor request parameters Michael Davidsaver via Tech-talk
Prev: Re: phoebus and subarrays in displays Kasemir, Kay via Tech-talk
Next: areaDetector build errors Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: PVA monitor request parameters Michael Davidsaver via Tech-talk
Next: RE: [EXTERNAL] Re: PVA monitor request parameters Pearson, Matthew via Tech-talk
