1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: phoebus and subarrays in displays
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Pierrick M Hanlet <[email protected]>
Date: Wed, 22 Jun 2022 20:32:02 +0000
> I'm using a recent version of phoebus and epics base 7.0.6.1.  When  displaying a subarray
> value, it always defaults to something such as ["PV-value"] with both  the double quotes and
> brackets displayed.  Is there a setting in which the brackets and quotes  can not be displayed?
When I display "sim://sinewave" or the "waveform" PV from https://github.com/ControlSystemStudio/phoebus/blob/master/core/pva/src/test/resources/demo.db in for example Applications, Display, Probe, I see the array in the format
[47.00, 48.00, 49.00, 50.00, 51.00]
with brackets but no quotes.
I'd only expect quotes when the array elements are strings.
When you say subarray, not sure what you mean, but is that what's adding the string format?
-Kay
phoebus and subarrays in displays Pierrick M Hanlet via Tech-talk
Prev: Re: PVA monitor request parameters Michael Davidsaver via Tech-talk
Next: RE: [EXTERNAL] Re: PVA monitor request parameters Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: phoebus and subarrays in displays Pierrick M Hanlet via Tech-talk
Next: areaDetector build errors Jong Woo Kim via Tech-talk
