1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: libusb problem
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 23 Jun 2022 22:00:10 +0000
Folks,
We are having a strange problem building the synApps dxp module on a new Ubuntu 22 system.
This is the command that fails:
/usr/bin/g++ -o dxpApp  -L/home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64 -L/home/epics/synApps/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -L/home/epics/synApps/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -L/home/epics/synApps/support/asyn-R4-42/lib/linux-x86_64 -L/home/epics/synApps/support/autosave-R5-10-2/lib/linux-x86_64 -L/home/epics/synApps/support/busy-R1-7-3/lib/linux-x86_64 -L/home/epics/synApps/support/calc-R3-7-4/lib/linux-x86_64 -L/home/epics/synApps/support/iocStats-3-1-16/lib/linux-x86_64 -L/home/epics/synApps/support/mca-R7-9/lib/linux-x86_64 -L/home/epics/synApps/support/seq-2-2-9/lib/linux-x86_64 -L/home/epics/synApps/support/sscan-R2-11-5/lib/linux-x86_64 -L/usr/local/epics/base-R7.0.4.1/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/asyn-R4-42/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/autosave-R5-10-2/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/busy-R1-7-3/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/calc-R3-7-4/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/iocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/mca-R7-9/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/seq-2-2-9/lib/linux-x86_64 -Wl,-rpath,/home/epics/synApps/support/sscan-R2-11-5/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-R7.0.4.1/lib/linux-x86_64          -rdynamic -m64         dxpMain.o dxp_registerRecordDeviceDriver.o    -ldxp -lhandel -lmca -lseq -lpv -lNDPlugin -lADBase -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -lnanohttp_stream -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom  -lusb -lX11 -lXext
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_open'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_release_interface'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_find_devices'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_set_configuration'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_init'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_bulk_write'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_set_debug'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_reset'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_claim_interface'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_close'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_get_busses'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_find_busses'
/usr/bin/ld: /home/epics/synApps/support/dxp-R6-0/lib/linux-x86_64/libhandel.so: undefined reference to `usb_bulk_read'
It is not finding the usb_* functions.  However, the third to last argument in the link command is –lusb.
This code uses the “old” version of libusb, i.e. libusb-0.1.x, not the new libusb-1.0.x.
The libusb-dev package is installed.  This is the library file:
epics@chemmat91:~/synApps/support/dxp-R6-0$ ls -l /usr/lib/x86_64-linux-gnu/libusb.so
-rw-r--r-- 1 root root 74 Mar 24 11:20 /usr/lib/x86_64-linux-gnu/libusb.so
That file is a GNU ld script:
epics@chemmat91:~/synApps/support/dxp-R6-0$ more /usr/lib/x86_64-linux-gnu/libusb.so
/* GNU ld script.  */
GROUP ( /lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4 )
It points to lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4.
This is the output of nm on that file showing symbols starting with usb_.  Note that all of the missing symbols in the link command are indeed defined in this file.
epics@chemmat91:~/synApps/support/dxp-R6-0$ nm -D /lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4 | grep usb_
00000000000045b0 T usb_bulk_read
0000000000004590 T usb_bulk_write
000000000000b148 B usb_busses
0000000000003b70 T usb_claim_interface
0000000000005920 T usb_clear_halt
0000000000003a70 T usb_close
0000000000003ea0 T usb_control_msg
000000000000b144 B usb_debug
0000000000003790 T usb_destroy_configuration
0000000000005bc0 T usb_detach_kernel_driver_np
0000000000002be0 T usb_device
0000000000009120 B usb_error_errno
0000000000009140 B usb_error_str
000000000000b140 B usb_error_type
00000000000041c0 T usb_fetch_and_parse_descriptors
0000000000004830 T usb_find_busses
00000000000053e0 T usb_find_devices
0000000000002c00 T usb_free_bus
0000000000003900 T usb_free_dev
0000000000002bf0 T usb_get_busses
0000000000004160 T usb_get_descriptor
00000000000040f0 T usb_get_descriptor_by_endpoint
0000000000005ab0 T usb_get_driver_np
0000000000003fa0 T usb_get_string
0000000000003fd0 T usb_get_string_simple
0000000000005810 T usb_init
00000000000045f0 T usb_interrupt_read
00000000000045d0 T usb_interrupt_write
0000000000003950 T usb_open
00000000000039c0 T usb_os_close
0000000000005140 T usb_os_determine_children
0000000000004610 T usb_os_find_busses
0000000000004a00 T usb_os_find_devices
0000000000005610 T usb_os_init
0000000000003930 T usb_os_open
0000000000002d50 T usb_parse_configuration
0000000000002c70 T usb_parse_descriptor
0000000000003ca0 T usb_release_interface
00000000000059f0 T usb_reset
0000000000005850 T usb_resetep
0000000000003d70 T usb_set_altinterface
0000000000003aa0 T usb_set_configuration
0000000000002b80 T usb_set_debug
0000000000002c10 T usb_strerror
Any ideas what could be wrong?
RE: libusb problem Mark Rivers via Tech-talk
Re: libusb problem Michael Davidsaver via Tech-talk
Prev: RE: Phoebus alarm does not honor filter Zhang, Tong via Tech-talk
Next: RE: AreaDetector Teledyne driver question Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: RE: AreaDetector Teledyne driver question Mark Rivers via Tech-talk
Next: RE: libusb problem Mark Rivers via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
