1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: libusb problem
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 23 Jun 2022 17:09:10 -0700
On 6/23/22 15:00, Mark Rivers via Tech-talk wrote:
It is not finding the usb_* functions.  However, the third to last argument in the link command is –lusb.
I wonder if the linker is finding libusb at some unexpected location?
Try:
make CMD_LDFLAGS=-Wl,--verbose
cf. https://linux.die.net/man/1/ld
This will make a lot of noise about the search process.
get.o
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/libpvxs.so failed
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/libpvxs.a failed
attempt to open /home/mdavidsaver/work/epics/pvxs/lib/linux-x86_64/libpvxs.so succeeded
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/libCom.so succeeded
libreadline.so.8 needed by /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/libCom.so
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/libreadline.so.8 failed
attempt to open /home/mdavidsaver/work/epics/pvxs/lib/linux-x86_64/libreadline.so.8 failed
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/../../../base-git/lib/linux-x86_64/libreadline.so.8 failed
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/../../lib/linux-x86_64/libreadline.so.8 failed
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/./libreadline.so.8 failed
attempt to open /usr/lib/x86_64-linux-gnu/fakechroot/libreadline.so.8 failed
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/libreadline.so.8 failed
attempt to open /usr/local/lib/i386-linux-gnu/libreadline.so.8 failed
attempt to open /lib/i386-linux-gnu/libreadline.so.8 failed
attempt to open /usr/lib/i386-linux-gnu/libreadline.so.8 failed
attempt to open /usr/local/lib/i686-linux-gnu/libreadline.so.8 failed
attempt to open /lib/i686-linux-gnu/libreadline.so.8 failed
attempt to open /usr/lib/i686-linux-gnu/libreadline.so.8 failed
attempt to open /usr/local/lib/libreadline.so.8 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libreadline.so.8 failed
found libreadline.so.8 at /lib/x86_64-linux-gnu/libreadline.so.8
libtinfo.so.6 needed by /lib/x86_64-linux-gnu/libreadline.so.8
attempt to open /home/mdavidsaver/work/epics/base-git/lib/linux-x86_64/libtinfo.so.6 failed
attempt to open /home/mdavidsaver/work/epics/pvxs/lib/linux-x86_64/libtinfo.so.6 failed
attempt to open /lib/x86_64-linux-gnu/../../../base-git/lib/linux-x86_64/libtinfo.so.6 failed
attempt to open /lib/x86_64-linux-gnu/../../lib/linux-x86_64/libtinfo.so.6 failed
attempt to open /usr/lib/x86_64-linux-gnu/fakechroot/libtinfo.so.6 failed
attempt to open /usr/lib/x86_64-linux-gnu/libfakeroot/libtinfo.so.6 failed
attempt to open /usr/local/lib/i386-linux-gnu/libtinfo.so.6 failed
attempt to open /usr/local/lib/i686-linux-gnu/libtinfo.so.6 failed
attempt to open /lib/i686-linux-gnu/libtinfo.so.6 failed
attempt to open /usr/lib/i686-linux-gnu/libtinfo.so.6 failed
attempt to open /usr/local/lib/libtinfo.so.6 failed
attempt to open /usr/local/lib/x86_64-linux-gnu/libtinfo.so.6 failed
found libtinfo.so.6 at /lib/x86_64-linux-gnu/libtinfo.so.6
libusb problem Mark Rivers via Tech-talk
Prev: Re: libusb problem Matt Newville via Tech-talk
Next: Re: Re: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: libusb problem Mark Rivers via Tech-talk
Next: RE: Problem with huge waveforms in EPICS 7 Mark Rivers via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
