1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Phoebus MBBO labels
From: "Smith, William via Tech-talk" <[email protected]>
Date: Mon, 27 Jun 2022 07:03:17 +0000
I have a number of mbbo records which have 16 possible values. Each value is named with a string. I would like to be able to enable or disable each bit of the mbbo. I have seen in the examples that the “slide button” widget is most appropriate for this. I would like the label of the slide widget to be the name from the field of the record.
I show one of the records below. I would like to take the enumerated values as use them as labels of the widget. This seems to be possible with a “radio button” but not with “slide button”. Is there a macro I can use like “$(pv_name)”? What’s the best way to achieve what I am aiming for?
Best,
Will
(bluesky) emil@sissy-serv-02:~$ caget -d31 MY-DEVICE-PREFIX:MBBO0
    Native data type: DBF_ENUM
    Request type:     DBR_CTRL_ENUM
    Element count:    1
    Value:            det1
    Status:           NO_ALARM
    Severity:         NO_ALARM
    Enums:            (15)
                      [ 0] ab_det
                      [ 1] bool_sig
                      [ 2] custom_test_device
                      [ 3] custom_test_flyer
                      [ 4] custom_test_signal
                      [ 5] det
                      [ 6] det1
                      [ 7] det2
                      [ 8] det3
                      [ 9] det4
                      [10] det5
                      [11] det_with_conf
                      [12] det_with_count_time
                      [13] direct_img
                      [14] direct_img_list
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Re: Phoebus MBBO labels Kasemir, Kay via Tech-talk
Prev: RE: Problem with huge waveforms in EPICS 7 Mark Rivers via Tech-talk
Next: Re: EPICS Collaboration Meeting September 2022 in Ljubljana Minca Čufer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: Phoebus MBBO labels Kasemir, Kay via Tech-talk
