Hi:
> > > The error "Record does not accept input" happens when you send a string (parsed with %s) to a record with an enum
> > > VAL
> > > like your mbbi, but the string does not match any of the enum strings in the record.
> > > As your record only has "STANDBY", "OPERATE" and "SELFTEST", it does not accept the input "MONITOR".
> > The mbbi should be in INVALID/CALC alarm state after that.
> Except.... that your record is "I/O Intr". Such records get all the available input but process only matching input.
> Non-matching input is silently ignored. That is by design how StreamDevice implements I/O Intr.
That all makes sense.
SCAN=I/O Intr checks everything but only reacts on match.
Anything else is assumed to be meant for some other record and thus ignored.
Maybe the issue could be avoided by changing the message from
error .. does not accept input 'MONITOR'
to something like
info .. value 'MONITOR' ignored because outside of expected values.
Cheers,
Kay
- Re: StreamDevice return state error Zimoch Dirk (PSI) via Tech-talk
- StreamDevice return state error Barrett (US), Patrick E via Tech-talk
Re: Phoebus connection to alarm server / Kafka Ian Gillingham via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
