1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: Phoebus connection to alarm server / Kafka
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Jun 2022 12:48:22 +0000
> To configure the GUI (in this case on Windows), should I set the "org.phoebus.applications.alarm/config_name=... " parameter in settings.ini or a .properties file? Do I need to add a runtime parameter to point Phoebus at the config file?
Put it into a settings.ini file, then mention that on the command line as
  phoebus[.bat, .sh, ...]  -settings /path/to/my/settings.ini
In a control room, operators should of course not have to type that every time, so you create script like /usr/local/bin/css that basically includes
  #!/bin/bash
  phoebus.sh  -settings /path/to/my/control_room_settings.ini "$@"
If you create a site-specific product, you can also bake your site-specific settings into that product.
-Kay
Prev: Re: StreamDevice return state error Zimoch Dirk (PSI) via Tech-talk
Next: RE: StreamDevice return state error Barrett (US), Patrick E via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: StreamDevice return state error Barrett (US), Patrick E via Tech-talk
Next: Doubts about DISS field Marco A. Barra Montevechi Filho via Tech-talk
