1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100
From: chengsn via Tech-talk <tech-talk at aps.anl.gov>
To: "heinz junkes" <junkes at fhi-berlin.mpg.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 30 Jun 2022 11:29:13 +0800 (GMT+08:00)
Thanks for your advice.
I have tried it on mvme6100, and it works fine.
Maybe EPICS 7 can also be built on RTEMS 6?
chengsn
IHEP
> -----Original Messages-----
> From: "Heinz Junkes" <junkes at fhi-berlin.mpg.de>
> Sent Time: 2022-06-29 22:29:43 (Wednesday)
> To: chengsn at ihep.ac.cn
> Subject: Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100
> Hello Chengsen,
> I was able to install RTEMS6 for Beatnik from the RTEMS master on 10.3. this year.
> You are welcome to try if that still works for you.
> Then NFSv4 can be used too.
> Here is my script for installing. If it doesn't work, I can send you the
> appropriate git-commits that worked for me.
> #!/bin/bash
> #RTEMS development
> export RTEMS_VERSION=6
> export RTEMS_ARCH=powerpc-rtems${RTEMS_VERSION}
> export RTEMS_ROOT=/home/rtems/MVME6100_WORK/rtems/${RTEMS_VERSION}
> #install rsb and rtems powerpc tools
> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> cd rsb
> cd rtems
> ../source-builder/sb-set-builder --jobs=4 --prefix=${RTEMS_ROOT} ${RTEMS_VERSION}/rtems-powerpc
> export PATH=${RTEMS_ROOT}/bin:${PATH}
> cd ../..
> # building kernel
> git clone git://git.rtems.org/rtems.git kernel
> cd kernel
> ./waf bsp_defaults --rtems-bsps=powerpc/beatnik > config.ini
> sed -i \
> -e "s|RTEMS_POSIX_API = False|RTEMS_POSIX_API = True|" \
> -e "s|BUILD_TESTS = False|BUILD_TESTS = True|" \
> config.ini
> ./waf configure --prefix=${RTEMS_ROOT}
> ./waf
> ./waf install
> cd ..
> # Add freebsd network
> git clone https://github.com/RTEMS/rtems-libbsd.git
> cd rtems-libbsd/
> git checkout 6-freebsd-12
> git checkout -b if_mve de0badf2c3aea5328936e583c842f58e80e56d62
> git submodule init
> git submodule update rtems_waf
> ./waf configure --prefix=${RTEMS_ROOT} --rtems-bsps=powerpc/beatnik --buildset=buildset/default.ini
> ./waf
> ./waf install
> #can be tested with this boot-image ...
> # powerpc-rtems6-objcopy -O binary ./build/powerpc-rtems6-beatnik-default/dhcpcd01.exe dhcpd01.boot
> cd ..
> git clone git://git.rtems.org/rtems-tools.git
> cd rtems-tools
> ./waf build install
> ./waf test
> cd ..
> Viele Grüße
> Heinz Junkes
> Experience directly varies with equipment ruined.
Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100 Heinz Junkes via Tech-talk
EPICS IOC BOOTP timeout at RTEMS on MVME6100 chengsn via Tech-talk
Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100 chengsn via Tech-talk
Prev: Re: Doubts about DISS field Andrew Johnson via Tech-talk
Next: Re: Doubts about DISS field Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100 Heinz Junkes via Tech-talk
Next: Re: EPICS IOC BOOTP timeout at RTEMS on MVME6100 Heinz Junkes via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
