1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: ADEiger R3-12-1 TriggerMode Puzzle
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 5 Jul 2022 18:12:55 +0000
Hi John,
Ø  i.e. if NumImages ~= 1, then trying to set TriggerMode = InternalEnable or ExternalEnable generates error messages at the IOC console
I just tested and there is indeed a bug.  When you select TriggerMode=Internal Enable or External Enable it should first set NumImages=1 before setting the TriggerMode.  That worked in R3-0 to R3-3.  I broke it in R3-4 during the refactoring to support TriggerMode=Continuous.
I have fixed it on the master branch and tested with an Eiger2 detector.
Ø  I see that the readback for various PVs display on the MEDM screen in yellow. They have .STAT = STATE. Looking at the MEDm screen shots in the ADEiger documentation this appears to be intentional.
Yes, that is intentional.  I use the Minor alarm state to indicate when a feature is enabled or disabled.  That makes it easy to see at a glance by color (yellow in medm), rather than having to read the string value.  I reserve Major alarm (red in medm) for real errors/problems.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of John Dobbins via Tech-talk
Sent: Tuesday, July 5, 2022 10:10 AM
To: tech-talk at aps.anl.gov
Subject: ADEiger R3-12-1 TriggerMode Puzzle
All,
I had been using ADEiger R2-7 with an EIGER2 and saw in the release notes for R2-8 a fix for a problem I observed:
Fixed a problem that occurs with 2020.2.2 firmware on the Eiger2.
Changing the TriggerMode to Internal Enable ("inte") or External Enable ("exte") fails if NumImages is not 1. The driver was changed to set NumImages=1 just before changing TriggerMode to either of these values.
I have updated to ADEiger R3-12-1 and still see this behavior, so I am puzzled.
epics> RestApi::put: [param=trigger_mode] server returned error code 400
2022/07/05 10:52:16.546 Param[TRIGGER_MODE]::basePut: [param=TRIGGER_MODE] underlying RestAPI put failed
2022/07/05 10:52:16.546 Param[TRIGGER_MODE]::put<int>: [param=TRIGGER_MODE] underlying basePut failed
2022/07/05 10:52:16.546 eigerDetector::writeInt32: error status=1 function=81, value=1
2022/07/05 10:52:16.546 EIG500:EIG:TriggerMode devAsynInt32::processCallbackOutput process write error
Did I go wrong somewhere?
EIGER2 Firmware Version   release-2020.2.6
SDK version                            1.8.0
Driver Version                        3.4.0
ADCore versioin                     3.12.1
Another question: I see that the readback for various PVs display on the MEDM screen in yellow. They have .STAT = STATE. Looking at the MEDm screen shots in the ADEiger documentation this appears to be intentional.
EIG500:EIG:Threshold1Enable_RBV
EIG500:EIG:FWEnable_RBV
EIG500:EIG:FlatfieldApplied_RBV
EIG500:EIG:CountrateCorrApplied_RBV
EIG500:EIG:PixelMaskApplied_RBV
EIG500:EIG:AutoSummation_RBV
EIG500:EIG:ArrayCallbacks_RBV
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADEiger R3-12-1 TriggerMode Puzzle John Dobbins via Tech-talk
Prev: ADEiger R3-12-1 TriggerMode Puzzle John Dobbins via Tech-talk
Next: Communication between EPICS and PLCs at your facility? Samadli, Ayaz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
