1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Communication between EPICS and PLCs at your facility?
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: "Samadli, Ayaz" <ayaz.samadli at xfel.eu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 6 Jul 2022 12:15:19 +0000
Hej Ayaz,
that is a good question. What we use and we recommend?
What is in use ?
For PLC-ish applications Modbus/TCP (I think it's called) is usesd.
There is a tool generating both PLC code and EPICS "databases" are generated based on a .def file.
For Motion Control with some additional IO and timestamping inside the PLC
we use a protocol based on ADS.
This solution is based on the model 3 motor driver, and there are too many details to be described here.
For more data-aqcuisition-heavy applications we have the epics-twincat-ads module,
which allows transfer of arrays and all other types of EPICS Records supported by asyn.
For Sample Environment Equipment, which is moved between beamlines and
even research institutes there is the Secop initiative:
https://github.com/SampleEnvironment/SECoP
Where the "EPICS Records" are provided by "octopy", but I am not an expert here.
And of course UPC-UA can be used - not my area of competence either.
So all in all, it depends how complex your PLC code is, requirements on data rates,
timestamping, slow control, medium slow control and faster controls.
This is all my personal view, which may be incomplete.
 HTH
/Torsten
On 2022-07-06, 13:05, "Tech-talk on behalf of Samadli, Ayaz via Tech-talk" <tech-talk-bounces at aps.anl.gov on behalf of tech-talk at aps.anl.gov> wrote:
    Dear All,
    At the European XFEL, we have an R&D project to replace the current custom communication protocol between our in-house SCADA system, Karabo, and PLCs (Beckhoff). I would be interested in your recommendations and current implementations for communications between EPICS (or other SCADA systems) and PLCs at your facility. Can you please share your experiences and suggestions with us?
    If you want to get more details, please feel free to reach out to me.
    Best Regards,
    Ayaz
    Ayaz Samadli
    Controls - Control Software Engineer
    European XFEL GmbH
    www.xfel.eu
    Headquarters: Holzkoppel 4, 22869 Schenefeld, Germany
    Managing Directors: Prof. Dr. Robert Feidenhans’l, Dr. Nicole Elleuche
    Registered as European X-Ray Free-Electron Laser Facility GmbH at
    Amtsgericht Hamburg, HRB 111165
Re: Communication between EPICS and PLCs at your facility? Timo Korhonen via Tech-talk
Communication between EPICS and PLCs at your facility? Samadli, Ayaz via Tech-talk
Prev: Communication between EPICS and PLCs at your facility? Samadli, Ayaz via Tech-talk
Next: Re: Communication between EPICS and PLCs at your facility? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Communication between EPICS and PLCs at your facility? Timo Korhonen via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
