1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Substitution file, streamdevice
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 11 Jul 2022 12:26:28 +0000
The answer to your question depends strongly on the details of your implementation.
Please provide your substitution file and template.
Dirk
On Mon, 2022-07-11 at 13:58 +0200, Donny Domagoj Cosic via Tech-talk wrote:
> Hello,
> I have a user.substitution file that contains a number of entries
> (vacuum pumps in this case) and it works well with the IOC. When all the
> pumps are connected, the IOC cycles through all the entries in the
> substitution file. However if we disconnect one pump, we receive a No
> Reply error from StreamDevice and the execution of the substitution file
> stops at that entry. The rest of the substitution file is skipped by the
> IOC until the next scan cycle where it again begins from the first entry
> in the substitution file. Therefore the entries after the No Reply are
> never executed.
> How can I get the IOC to continue to the next entry in the substitution
> file when a No Reply error (for an IN command) is encountered?
> Thank you in advance,
Re: Substitution file, streamdevice Donny Domagoj Cosic via Tech-talk
Prev: Substitution file, streamdevice Donny Domagoj Cosic via Tech-talk
Next: CSS questions pertaining to combo box showing values after decimal point Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Substitution file, streamdevice Donny Domagoj Cosic via Tech-talk
