1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Substitution file, streamdevice
From: Donny Domagoj Cosic via Tech-talk <tech-talk at aps.anl.gov>
To: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 11 Jul 2022 13:58:49 +0200
Hello,
I have a user.substitution file that contains a number of entries (vacuum pumps in this case) and it works well with the IOC. When all the pumps are connected, the IOC cycles through all the entries in the substitution file. However if we disconnect one pump, we receive a No Reply error from StreamDevice and the execution of the substitution file stops at that entry. The rest of the substitution file is skipped by the IOC until the next scan cycle where it again begins from the first entry in the substitution file. Therefore the entries after the No Reply are never executed. How can I get the IOC to continue to the next entry in the substitution file when a No Reply error (for an IN command) is encountered?
Thank you in advance,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: dcosic at irb.hr | www.irb.hr
Re: Substitution file, streamdevice Zimoch Dirk (PSI) via Tech-talk
Prev: Re: How to safely implement an asynPortDriver with SCAN records Jure Varlec via Tech-talk
Next: Re: Substitution file, streamdevice Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: PHP_EPICS module Remi Faure via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
