1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: How to safely implement an asynPortDriver with SCAN records
From: Jure Varlec via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 11 Jul 2022 07:46:54 +0000
When faced with this issue, I opted for simply disabling the port via pasynManager from the epicsAtExit() hook before deleting the driver instance. This makes asynManager reject the calls from the scan threads, so it doesn't touch the driver anymore. As a side effect, several error messages may be printed at IOC exit, but they are harmless. I also experimented with calling asynPortDriver::disconnect(), but the result is the same, except the messages printed are different, and I think the messages printed when the port is disabled are a bit less confusing.
Best,
Jure
From: Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
Sent: Friday, July 8, 2022 22:37
To: Mark Rivers <[email protected]>; Andrew Johnson <[email protected]>; Érico Nogueira Rolim <[email protected]>
Caution: This email originated from outside of Cosylab.
On 7/8/22 11:11, Mark Rivers via Tech-talk wrote:
> Hi Andrew,
> To be honest I have not paid enough attention to how to correctly handle destructors in asynPortDriver.
On the occasions when I've used asynPortDriver, I put a cantProceed() in the sub-class destructor.
After a call to registerInterface(), the asynInterface::drvPvt pointer must remain valid until
the process exits.  So an asyn port can't be destroyed.
I've toyed with the ideas like re-counter asynUser, or somehow later setting drvPvt=NULL.
Both seem possible, but not without quite some effort.
This situation is made more complicated by the fact that IOC scan threads are not stopped on exit.
We do now stop them during database unit tests.  However, some ~vague compatibility concerns have
so far kept this from being done for full IOCs.
Personally, as a matter of good practice, drivers I write always include an epicsAtExit() handler
which stops any worker threads.
Also, I should mention the de-init hooks added in Base 7.0.4 to decouple database shutdown from
process exit.
https://github.com/epics-base/epics-base/commit/5d5e552a7ec6ef69459c97b0081aa775372a6290#diff-02e4602d43dbb03b4097bb26382a1db92367fb55fe791415cd32d4f234875d92R50
For compatibility, the effect of initHookAtShutdown can mostly be replicated by calling epicsAtExit()
at initHookAfterIocRunning.
> This is one of Erico’s tracebacks.
> ==2685== Invalid read of size 4
> ==2685==    at 0x7BFA904: __pthread_mutex_lock_full (pthread_mutex_lock.c:176)
> ==2685==    by 0x5E92CA5: epicsMutexOsdLock (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x5093A5F: asynPortDriver::lock() (in /opt/epics/synApps-lnls-R1-2-1/support/asyn-R4-35/lib/linux-x86_64/libasyn.so)
> ==2685==    by 0x50927BB: readUInt32Digital (in /opt/epics/synApps-lnls-R1-2-1/support/asyn-R4-35/lib/linux-x86_64/libasyn.so)
> ==2685==    by 0x50ABF79: processCallbackInput (in /opt/epics/synApps-lnls-R1-2-1/support/asyn-R4-35/lib/linux-x86_64/libasyn.so)
> ==2685==    by 0x5071EE2: portThread (in /opt/epics/synApps-lnls-R1-2-1/support/asyn-R4-35/lib/linux-x86_64/libasyn.so)
> ==2685==    by 0x5E90A9B: start_routine (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x7BFCEA4: start_thread (pthread_create.c:307)
> ==2685==    by 0x90EBB0C: clone (clone.S:111)
> ==2685==  Address 0xe8b7b20 is 16 bytes inside a block of size 48 free'd
> ==2685==    at 0x4C2B06D: free (vg_replace_malloc.c:540)
> ==2685==    by 0x5E8BB55: epicsMutexDestroy (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x5094D76: asynPortDriver::~asynPortDriver() (in /opt/epics/synApps-lnls-R1-2-1/support/asyn-R4-35/lib/linux-x86_64/libasyn.so)
> ==2685==    by 0x5E86FB2: epicsExitCallAtExits (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x5E87357: epicsExit (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x40786C: main (in /opt/epics/ioc/fofb-epics-ioc/bin/linux-x86_64/FOFB)
> ==2685==  Block was alloc'd at
> ==2685==    at 0x4C2C089: calloc (vg_replace_malloc.c:762)
> ==2685==    by 0x5E92B24: epicsMutexOsdCreate (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x5E8B98E: epicsMutexOsiCreate (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x5097584: asynPortDriver::initialize(char const*, int, int, int, int, int, int, int) (in /opt/epics/synApps-lnls-R1-2-1/support/asyn-R4-35/lib/linux-x86_64/libasyn.so)
> ==2685==    by 0x5098713: asynPortDriver::asynPortDriver(char const*, int, int, int, int, int, int, int) (in /opt/epics/synApps-lnls-R1-2-1/support/asyn-R4-35/lib/linux-x86_64/libasyn.so)
> ==2685==    by 0x63C80F3: asynNDArrayDriver::asynNDArrayDriver(char const*, int, int, unsigned long, int, int, int, int, int, int) (in /opt/epics/synApps-lnls-R1-2-1/support/areaDetector-R3-6/ADCore/lib/linux-x86_64/libADBase.so)
> ==2685==    by 0x4E4A02C: drvFOFB::drvFOFB(char const*, char const*, int, char const*, int, int, int, int, unsigned long) (in /opt/epics/ioc/fofb-epics-ioc/lib/linux-x86_64/libFOFBSupport.so)
> ==2685==    by 0x4E4C58B: drvFOFBConfigure (in /opt/epics/ioc/fofb-epics-ioc/lib/linux-x86_64/libFOFBSupport.so)
> ==2685==    by 0x4E4C5E7: initCallFunc (in /opt/epics/ioc/fofb-epics-ioc/lib/linux-x86_64/libFOFBSupport.so)
> ==2685==    by 0x5E81B9F: iocshBody (in /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9)
> ==2685==    by 0x407851: main (in /opt/epics/ioc/fofb-epics-ioc/bin/linux-x86_64/FOFB)
> So asynPortDriver created an epicsMutex. Erico’s destructor deleted itself and the base asynPortDriver, which deleted the epicsMutex.  But then processCallbackInput (from a scan task?) called readUInt32Digital, which tried to call the now destroyed asynPortDriver object.
> How is this supposed to work?  I believe he registered epicsAtExit in the dynamic constructor for his class that was called from st.cmd.  I think that is before the scan tasks are created if it is done before iocInit, correct? So it should be deleted after the scan tasks?  Is the problem that the port thread created by asynManager has a queue that is calling processCallbackInput, and that is still running even if the scan task has been deleted?
> Mark
> *From:* Andrew Johnson <[email protected]>
> *Sent:* Friday, July 8, 2022 12:43 PM
> *To:* Érico Nogueira Rolim <[email protected]>; Mark Rivers <[email protected]>
> *Cc:* tech-talk <[email protected]>
> *Subject:* Re: How to safely implement an asynPortDriver with SCAN records
> On 7/8/22 12:27 PM, Érico Nogueira Rolim via Tech-talk wrote:
>     Thank you for the quick answer!
>     On 08/07/2022 12:23, Mark Rivers wrote:
>         Hi Érico,
>         The asynPort driver base class does not have an exit handler to destroy itself when the IOC is exiting, that is left to derived classes.  Does your derived class establish an exit handler with epicsAtExit?
>         What leads you to believe that the asynPortDriver destructor is being called?
>     I'm sorry for the confusion, I meant to say that the destructor for our class that's derived from asynPortDriver is called. And indeed, we have its destructor registered with epicsAtExit (a bit ugly):
>     static void exitHandlerC(void *pPvt)
>          drvFOFB *pdrvFOFB = (drvFOFB *)pPvt;
>          pdrvFOFB->~drvFOFB();
>     We do this because the destructor is responsible for closing quite a few resources before we exit. I'm open to suggestions on better ways to do this.
> Not sure if this is relevant, but when do you register that exit handler? The registered epicsAtExit() routines are called in the reverse order in which they were added, so to ensure that your shutdown routines are called /before/ any that the IOC or asyn registers you should register yours /afterwards/. Calling epicsAtExit() from a static C++ constructor is likely to cause these kinds of problems, if that's where you put it try moving that to a routine which gets run from a command in your st.cmd file (in general a driver that needs one should register an exit routine for each device as it gets created by the associated st.cmd command).
> HTH,
> - Andrew
> Complexity comes for free, Simplicity you have to work for.
How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
RE: How to safely implement an asynPortDriver with SCAN records Mark Rivers via Tech-talk
Re: How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
Re: How to safely implement an asynPortDriver with SCAN records Andrew Johnson via Tech-talk
Re: How to safely implement an asynPortDriver with SCAN records Michael Davidsaver via Tech-talk
Prev: Re: How to safely implement an asynPortDriver with SCAN records Michael Davidsaver via Tech-talk
Next: Substitution file, streamdevice Donny Domagoj Cosic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
