1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: ADEiger acquisiton problem
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 14 Jul 2022 14:45:28 +0000
Hi John,
Did you check to see if the data file is present on their device server, and the problem is just that it did not get copied to the local file system?
Does it make any difference if you disable compression in the Filewriter interface?
Can you run camonitor on AcquireMessage and DetectorState to see if there are any status changes that flash by?
Sent: Thursday, July 14, 2022 9:23 AM
To: Mark Rivers <rivers at cars.uchicago.edu>
Mark,
External Enable, External Series, Internal Enable work as expected.
Internal Series generates only a master file.  Acquire Staus = Done after acquisition. Image Counter does not increment. There are no messages at the IOC console.
Attached an image post Internal Series acquisition. I set image counter to zero before acquisition.
Internal Series seems to work with stream. The image counter increments. The plugin NDFileHDF5 writes a file if enabled.
John
Sent: Wednesday, July 13, 2022 4:40 PM
Subject: RE: ADEiger acquisiton problem
Hi John,
Are there any error messages on the IOC console?
Does the Acquire PV go back to done?
Can you send an medm screen shot at the end of the acquisition?
Can you try using Stream mode and see if that works?  I know we have an Eiger2 16M at APS 12-ID that is used in Stream mode and it is working OK.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of John Dobbins via Tech-talk
Sent: Wednesday, July 13, 2022 3:34 PM
To: tech-talk at aps.anl.gov
Subject: ADEiger acquisiton problem
I am encountering a problem with acquisition on an EIGER2 which I haven't experienced before (on other EIGERs)
This appears to be true with both the latest ADEiger and an older version (Driver 2-5, ADCore 3.10.0)
I have an EIGER2 16M, firmware 2020.2.1
If I set TriggerMode = Internal Series, NumImages =1 , AcquireTime = 1.0 and press Start the MEDM screen reports the detector going through all the expected states  (Arming, Triggering, Processing Files) .  An HDF5 master files appears but no data file. Also the image counter does not increment.
External Trigger works as expected.
When tested separately from EPICS (a locally written program sending HTTP requests) the acquisition occurs as expected.
Any advice appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADEiger acquisiton problem John Dobbins via Tech-talk
RE: ADEiger acquisiton problem Mark Rivers via Tech-talk
Re: ADEiger acquisiton problem John Dobbins via Tech-talk
Prev: Re: [EXTERNAL] Phoebus Alarm Area Panel custom colours Ian Gillingham via Tech-talk
Next: motor driver only works with asyn traces turned on Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: ADEiger acquisiton problem John Dobbins via Tech-talk
Next: extensions CONFIG_SITE file for linux-aarch64 of Raspberry Pi 64-bit OS Akira Chen via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
