1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus Alarm Area Panel custom colours
From: Ian Gillingham via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 14 Jul 2022 15:29:42 +0100
Thanks for that Kay.
I totally understand the reasoning for not making the alarm area panel colours customisable. The main reason I looked into this was because the end user asked the question. I think the important part is that colours can be customised on the main synoptic display for the plant, but thought I'd better check out the alarm area panel display as well. It's good to have the definitive answer.
Thanks again!
Ian
On 14/07/2022 15:15, Kasemir, Kay wrote:
Hi:
> I'm trying to see if there's a way to modify the alarm colours presented
on the Phoebus Alarm Area Panel.
In there, they are currently fixed.
In part because it's considered important to have one set of alarm colors, so users know what's what. We certainly don't want to use red in one tool for 'MAJOR' alarm and in another tool for 'OK'.
In part because so far no site that uses these alarm tools saw the need to customize them.
If you have spare cycles, feel free to make them customizable, but if you then use that, you should assert that the colors used by displays (and this should also include web displays of control system info) use a consistent set of colors across your site.
Kay
Ian Gillingham
Phoebus Alarm Area Panel custom colours Ian Gillingham via Tech-talk
Re: [EXTERNAL] Phoebus Alarm Area Panel custom colours Kasemir, Kay via Tech-talk
Prev: Re: ADEiger acquisiton problem John Dobbins via Tech-talk
Next: Re: ADEiger acquisiton problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Phoebus Alarm Area Panel custom colours Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Phoebus Alarm Area Panel custom colours Maren Purves via Tech-talk
