1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: CS-Studio: File Manager configuration when executing external command
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Zhang, Tong" <ZhangT at frib.msu.edu>
Date: Thu, 21 Jul 2022 14:58:58 +0000
> After the external application is started up through the “Execute Command” action of an ActionButton, everything looks to be working well, but when doing the save/open businesses through the external app interface, it seems that the current user File Manager configuration is not being honored, e.g. you cannot see any bookmarked locations on the pop-up file/directory open dialog
Not sure what the difference is, but that works for me in the most recent version of CS-Studio, i.e. the one that no longer relies on Eclipse.
I've opened gedit, added a "tmp" bookmark to its file locator.
Then I opened CS-Studio/phoebus, opened the example displays, "Actions", "Open *.def file" which on Linux opens gedit, opened the file locator in gedit -> It shows the "tmp" bookmark.
-Kay
RE: CS-Studio: File Manager configuration when executing external command Zhang, Tong via Tech-talk
Prev: Re: [EXTERNAL] Phoebus Scan Server Kasemir, Kay via Tech-talk
Next: RE: CS-Studio: File Manager configuration when executing external command Zhang, Tong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: CS-Studio: File Manager configuration when executing external command Zhang, Tong via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
