Kay, I’m talking about CS-Studio on Eclipse, not Phoebus.
The difference is the highlighted in the box, where I created a bookmark called datafiles, but it could not be seen in the Open dialog in CS-Studio, I forgot to mention, it is not necessary happening with
external app calling, but from any Open action from CS-Studio, e.g. Open an OPI through the menu.
I also tested against Phoebus, it works without such issue. But I’m looking for a solution for CS-Studio.
Tong
Sent: Thursday, July 21, 2022 10:59
To: tech-talk at aps.anl.gov; Zhang, Tong <ZhangT at frib.msu.edu>
Subject: Re: CS-Studio: File Manager configuration when executing external command
[EXTERNAL] This email originated from outside of FRIB
> After the external application is started up through the “Execute Command” action of an ActionButton, everything looks to be working well, but when doing the save/open businesses through the
external app interface, it seems that the current user File Manager configuration is not being honored, e.g. you cannot see any bookmarked locations on the pop-up file/directory open dialog
Not sure what the difference is, but that works for me in the most recent version of CS-Studio, i.e. the one that no longer relies on Eclipse.
I've opened gedit, added a "tmp" bookmark to its file locator.
Then I opened CS-Studio/phoebus, opened the example displays, "Actions", "Open *.def file" which on Linux opens gedit, opened the file locator in gedit -> It shows the "tmp" bookmark.
- CS-Studio: File Manager configuration when executing external command Zhang, Tong via Tech-talk
- Re: CS-Studio: File Manager configuration when executing external command Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Phoebus Scan Server Ian Gillingham via Tech-talk
<2022>
2025
PyDevice modbus liuxiaomin via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
