1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: PyDevice modbus
To: "Smith, Martin via Tech-talk" <[email protected]>, liuxiaomin <[email protected]>
Date: Fri, 22 Jul 2022 11:36:22 +0000
Hi  Xiaomin,
> Because the register address of the values not continuous, so I did not use the Modbus module under EPICS,
Beginning with Modbus R2-9 (August 23, 2016) there is support for "absolute" Modbus addressing, so it works fine even if the register addresses are not continuous.  So there is no reason not to us the EPICS modbus module.
From: Tech-talk <[email protected]> on behalf of liuxiaomin via Tech-talk <[email protected]>
Sent: Friday, July 22, 2022 1:14 AM
To: Smith, Martin via Tech-talk <[email protected]>
Subject: PyDevice modbus
I am trying to control a device which can get the temperature values ,Because the register address of the values not continuous, so I did not use the Modbus module under EPICS, but used modbus_tk under python to get the value. In order to match with EPICS, I used the support module PyDevice which is an EPICS device support for Python interpreter, When I run the st.cmd file, the following error occurs, So now there are three files, the db file, the st.cmd file and the wave.py file that gets the temperature data.
The db files is as flollows:
record(ai, "$(user):GETDATA")
   field(DTYP, "pydev")
   field(INP,"@temp1.getData()")
   field(SCAN, "1 second")
record(waveform, "$(user):TEMP")
   field(INP, "@pydev.iointr('temp_sent')")
   field(SCAN, "I/O Intr")
   #field(INP, "@temp1.temp_array")
   field(NELM, "1000")
   field(FTVL, "DOUBLE")
The st.cmd files is as follows:
#!../../bin/linux-x86_64/waveioc
< envPaths
epicsEnvSet("EPICS_CA_SERVER_PORT", 5070)
epicsEnvSet("IOCNAME","waveioc")
cd "${TOP}"
dbLoadDatabase "dbd/waveioc.dbd"
waveioc_registerRecordDeviceDriver pdbbase
drvModbusAsynConfigure("WORDIR","CAT1",slaveAddress,modbusFunction,modbusStartAddr,modbusLen,dataType,posMsec,"plcType")
pydev("import sys; sys.path.insert(0,'${PWD}')")
pydev("import modbus_tk")
pydev("from wave import Temp")
pydev("temp1 = Temp('192.168.0.11','502')")
dbLoadRecords "db/dbWaveform.db", "user=${IOCNAME}"
cd "${TOP}/iocBoot/${IOC}"
iocInit
I encounter a problem, the obtained temperature values are all 0, the real temperature are not 0. If only used  modbus_tk without PyDevice, there is no such error, and can caget the real temperature .
caget   waveioc:TEMP
waveioc:TEMP   0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
When the command file runs, it shows:
< envPaths
epicsEnvSet("IOC","waveioc")
epicsEnvSet("TOP","/home/iocusr/xm/waveioc")
epicsEnvSet("MODULES","/opt/epics/base/../modules")
epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
epicsEnvSet("PYDEVICE","/opt/PyDevice")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
cd "/home/iocusr/xm/waveioc"
Executing Python code: import pydev
Executing Python code: import builtins
Executing Python code: builtins.pydev=pydev
Executing Python code: import modbus_tk
Traceback (most recent call last):
  File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'modbus_tk'
Executing Python code: from wave import Temp
  File "/usr/lib/python3.7/wave.py", line 2, in <module>
    import modbus_tk
Executing Python code: temp1 = Temp('192.168.0.11','502')
NameError: name 'Temp' is not defined
dbLoadRecords "db/dbWaveform.db", "user=waveioc"
cd "/home/iocusr/xm/waveioc/iocBoot/waveioc"
iocInit
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-09-13T15:44+0800
sevr=info s7plcInit: no stations configured
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
epics>
 Why can't I get the real temperature value?
Thanks
xiaomin
PyDevice modbus liuxiaomin via Tech-talk
Prev: PyDevice modbus liuxiaomin via Tech-talk
Next: ci-scripts 3.4 release: more cross-compiling options, Python hooks Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: [EXTERNAL] PyDevice modbus Vodopivec, Klemen via Tech-talk
