1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: [EXTERNAL] PyDevice modbus
From: "Vodopivec, Klemen via Tech-talk" <tech-talk at aps.anl.gov>
To: liuxiaomin <liuxiaomin at sari.ac.cn>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 31 Aug 2022 12:14:19 +0000
Hi Xiaomin,
Have you solved this already?
From the Python errors you’re getting, it appears your include path is not finding the modbus_tk module. If it works from a regular python3 shell, you can check where’s it’s located with
> import modbus_tk
> print(modbus_tk.__file__)
And then make sure that’s in your include path.
Because the wave.py tries to import modbus_tk too and fails, it doesn’t execute the code after the exception, which is probably why Temp class doesn’t get defined.
— Klemen
> On Jul 22, 2022, at 2:14 AM, liuxiaomin via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hi,
> I am trying to control a device which can get the temperature values ,Because the register address of the values not continuous, so I did not use the Modbus module under EPICS, but used modbus_tk under python to get the value. In order to match with EPICS, I used the support module PyDevice which is an EPICS device support for Python interpreter, When I run the st.cmd file, the following error occurs, So now there are three files, the db file, the st.cmd file and the wave.py file that gets the temperature data.
> The db files is as flollows:
> record(ai, "$(user):GETDATA")
>    field(DTYP, "pydev")
>    field(INP,"@temp1.getData()")
>    field(SCAN, "1 second")
> record(waveform, "$(user):TEMP")
>    field(INP, "@pydev.iointr('temp_sent')")
>    field(SCAN, "I/O Intr")
>    #field(INP, "@temp1.temp_array")
>    field(NELM, "1000")
>    field(FTVL, "DOUBLE")
> The st.cmd files is as follows:
> #!../../bin/linux-x86_64/waveioc
> < envPaths
> epicsEnvSet("EPICS_CA_SERVER_PORT", 5070)
> epicsEnvSet("IOCNAME","waveioc")
> cd "${TOP}"
> ## Register all support components
> dbLoadDatabase "dbd/waveioc.dbd"
> waveioc_registerRecordDeviceDriver pdbbase
> drvModbusAsynConfigure("WORDIR","CAT1",slaveAddress,modbusFunction,modbusStartAddr,modbusLen,dataType,posMsec,"plcType")
> pydev("import sys; sys.path.insert(0,'${PWD}')")
> pydev("import modbus_tk")
> pydev("from wave import Temp")
> pydev("temp1 = Temp('192.168.0.11','502')")
> dbLoadRecords "db/dbWaveform.db", "user=${IOCNAME}"
> cd "${TOP}/iocBoot/${IOC}"
> iocInit
> I encounter a problem, the obtained temperature values are all 0, the real temperature are not 0. If only used  modbus_tk without PyDevice, there is no such error, and can caget the real temperature .
> caget   waveioc:TEMP
> waveioc:TEMP   0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
> When the command file runs, it shows:
> < envPaths
> epicsEnvSet("IOC","waveioc")
> epicsEnvSet("TOP","/home/iocusr/xm/waveioc")
> epicsEnvSet("MODULES","/opt/epics/base/../modules")
> epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
> epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
> epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
> epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
> epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
> epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
> epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
> epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
> epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
> epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
> epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
> epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
> epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
> epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
> epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
> epicsEnvSet("PYDEVICE","/opt/PyDevice")
> epicsEnvSet("EPICS_BASE","/opt/epics/base")
> cd "/home/iocusr/xm/waveioc"
> Executing Python code: import pydev
> Executing Python code: import builtins
> Executing Python code: builtins.pydev=pydev
> Executing Python code: import modbus_tk
> Traceback (most recent call last):
>   File "<string>", line 1, in <module>
> ModuleNotFoundError: No module named 'modbus_tk'
> Executing Python code: from wave import Temp
>   File "/usr/lib/python3.7/wave.py", line 2, in <module>
>     import modbus_tk
> Executing Python code: temp1 = Temp('192.168.0.11','502')
> NameError: name 'Temp' is not defined
> dbLoadRecords "db/dbWaveform.db", "user=waveioc"
> cd "/home/iocusr/xm/waveioc/iocBoot/waveioc"
> iocInit
> Starting iocInit
> ## EPICS R7.0.5
> ## Rev. 2021-09-13T15:44+0800
> sevr=info s7plcInit: no stations configured
> drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
> iocRun: All initialization complete
> epics>
>  Why can't I get the real temperature value?
> Thanks
> xiaomin
PyDevice modbus liuxiaomin via Tech-talk
Prev: Re: EPICS on ESP32 Steve Hunt via Tech-talk
Next: Building with INSTALL_PATH= Dudley, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: PyDevice modbus Mark Rivers via Tech-talk
Next: ci-scripts 3.4 release: more cross-compiling options, Python hooks Ralph Lange via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
