1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Building with INSTALL_PATH=
From: "Dudley, David via Tech-talk" <[email protected]>
Date: Wed, 31 Aug 2022 13:29:37 +0000
So…
I’m building with EPICS 7 – current github release.
Trying to build into a directory –other- than where it’s stored (it’s on a USB stick, would rather the result be on the internal SSD).
Doing building using ‘make INSTALL_LOCATION=xxx’, and things go OK for a while.  Everything gets loaded onto the SSD.
Now, that’s until the build gets down to needing ‘makeMakeFile.pl’ or one of the other perl scripts.  Those insist on being invoked directly from the bin directory of the source structure.
Adding a bin directory (in my case, ./bin/linux-86_64/) and copying all the perl scripts over from where they were successfully installed, things continue building correctly.
Next problem that occurs is related to testCa, where again, it’s trying to use files that were built into another location, as if they’re local.  This error is for referencing  ‘softIoc.dbd’
Then… it’s trying to load some modules from lib/perl in the source directory.
Do I need to add something else to this?
BTW: changing INSTALL_PATH in the CONFIG_SITE file doesn’t make this work, and I’m trying to do all of this –without- modifying any of the downloaded files.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
Re: Building with INSTALL_PATH= Andrew Johnson via Tech-talk
Prev: Re: [EXTERNAL] PyDevice modbus Vodopivec, Klemen via Tech-talk
Next: Problem with DB_INSTALLS in Makefile Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS on ESP32 Siddons, David via Tech-talk
Next: Re: Building with INSTALL_PATH= Andrew Johnson via Tech-talk
