1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Retrieving record name from aSub input/output fields
From: Andrew Johnson via Tech-talk <[email protected]>
To: "Wang, Andrew" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 27 Jul 2022 11:25:41 -0500
Hi Andy,
On 7/26/22 6:53 PM, Wang, Andrew via Tech-talk wrote:
Update. I think I got it. I had to do the following.
static long func(aSubRecord *prec)
    DBLINK inpa = prec->inpa;
    char *rec_name = inpa.value.pv_link.pvname;
    printf("Record name in INPA is %s\n", rec_name);
    return 0;
A DBLINK is a structure (not a pointer) so your first line of code is copying data that you don't need to do, and the value.pvlink union member is only valid for certain kinds of link, so I would suggest something like this, which adds protection from that by only showing DB and CA links:
    DBLINK *plink = &prec->inpa;
    if (plink->type == DB_LINK ||
plink->type == CA_LINK) {
        const char *target = plink->value.pv_link.pvname;
        printf("Record %s.INPA links to %s\n", prec->name,
target);
    return 0;
HTH,
- Andrew
Sent: Tuesday, July 26, 2022 4:17 PM
To: EPICS tech-talk <[email protected]>
Subject: Retrieving record name from aSub input/output fields
Hi all,
Quick question this time. I was wondering if there was a way to retrieve the name of the record referenced in an OUTLINK/INLINK field such as INPA, OUTA, etc. in the aSub routine.
For instance, suppose I had an aSub record such as the following.
record(aSub, “example”)
                field(SNAM, “func”)
                field(INPA,   “rec_in_inpa”)
I would like to be able to print the name of the record in INPA within “func”.
                char *rec_name = prec->____;
                printf(“Record name in INPA is %s\n”, rec_name);
                return 0;
Andy
Purple ribbon awareness
Complexity comes for free, Simplicity you have to work for.
Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Re: Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Prev: Re: Retrieving record name from aSub input/output fields Michael Davidsaver via Tech-talk
Next: Re: Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: PVA and Docker on Mac Juan F. Esteban Müller via Tech-talk
