1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Retrieving record name from aSub input/output fields
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 27 Jul 2022 16:28:11 +0000
HI Michael and Andrew,
Thank you for the suggestion! That is a good idea to check the input type before proceeding further with the union.
Yeah, so the reason I am doing this is because I am interested in using the streamReload function from StreamDevice for certain records. I didn't want to hard code the record name for the streamReload function and would rather use the record name specified in the input links.
For instance, in my aSub function, I wanted to steer away from doing this:
record(aSub, "reload_rec_for_setting_voltage")
      field(SNAM, "reload")
static long reload(aSubRecord *prec)
      streamReload("voltage_rec")
      return 0;
My aim was to do this instead:
      field(INPA,   "voltage_rec")
     DBLINK inpa = prec->inpa;
     if (inpa.type == DB_LINK)
             char *rec_name = inpa.value.pv_link.pvname;
            streamReload(rec_name);
This will allow me to use the aSub record for other records I want to apply streamReload to. I didn't want to create 10+ individual functions for each record I wanted to use streamReload on.
Andy
Sent: Wednesday, July 27, 2022 8:30 AM
To: Wang, Andrew <[email protected]>
On 7/26/22 16:53, Wang, Andrew via Tech-talk wrote:
> Update. I think I got it. I had to do the following.
> static long func(aSubRecord *prec)
Be aware that 'inpa.value' is a C union.
So it is strongly recommended to test 'prec->inp.type' before accessing.
In this case you are assuming that 'prec->inp.type==DB_LINK'.
>                  printf(“Record name in INPA is %s\n”, rec_name);
Also, what motivates this?  Have you found an operation that
isn't covered by the link abstraction?
>                  return 0;
> *From:* Wang, Andrew
> *Sent:* Tuesday, July 26, 2022 4:17 PM
> *To:* EPICS tech-talk <[email protected]>
> *Subject:* Retrieving record name from aSub input/output fields
> Hi all,
> Quick question this time. I was wondering if there was a way to retrieve the name of the record referenced in an OUTLINK/INLINK field such as INPA, OUTA, etc. in the aSub routine.
> For instance, suppose I had an aSub record such as the following.
> record(aSub, “example”)
>                  field(SNAM, “func”)
>                  field(INPA,   “rec_in_inpa”)
> I would like to be able to print the name of the record in INPA within “func”.
>                  char *rec_name = prec->____;
>                  return 0;
> Thanks,
> Andy
> Purple ribbon awareness <https://urldefense.us/v3/__https://www.disabled-world.com/disability/awareness/ribbons.php*purple__;Iw!!G2kpM7uM-TzIFchu!inuIyxNM2XJXWKnvIjTejbSyl70ULfXoS2SJBJ1rrGgMtiBGic7GoQpea6to21OpaNc$ >
Re: Retrieving record name from aSub input/output fields Michael Davidsaver via Tech-talk
Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Re: Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Prev: Re: Retrieving record name from aSub input/output fields Andrew Johnson via Tech-talk
Next: RE: PINI field not working with modbus Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Retrieving record name from aSub input/output fields Michael Davidsaver via Tech-talk
Next: Re: Retrieving record name from aSub input/output fields Michael Davidsaver via Tech-talk
