> I would hope there is some field could be used to define the record as ‘read-only’,
The "rules" in channel access security can include a value from a process variable, so you could define a variable such that when "PV==1" then predesignated records could go to a "read-only" state.
You can also write your own custom records that would have a "read-only" field, if that is what you really want, but for the standard records in EPICS base you would use channel access security.
Ned
I know that channel access security can control the record write permission based on a wide range of rules, but I’m wondering if EPICS has some other way to control the write permission of a record generally from the record definition level? To make it clearer,
I would hope there is some field could be used to define the record as ‘read-only’, that is all external CA put request should be denied, the data only could be updated through the internal device support.
Tong
- Write permission of a record Zhang, Tong via Tech-talk
Re: Write permission of a record Andrew Johnson via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
