1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Write permission of a record
From: Andrew Johnson via Tech-talk <[email protected]>
To: "Zhang, Tong" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 1 Aug 2022 15:06:49 -0500
Hi Tong,
There is a field in every record type called DISP (Disable Put) which, when set to a non-zero value, prevents any other field of that record from being written to over Channel Access or PV Access. You can still write to the DISP field remotely though, and it doesn't prevent DB links from other records in the same IOC from changing any record fields though, so it might not be quite what you're after but it's pretty close.
- Andrew
On 8/1/22 2:50 PM, Zhang, Tong via Tech-talk wrote:
I know that channel access security can control the record write permission based on a wide range of rules, but I’m wondering if EPICS has some other way to control the write permission of a record generally from the record definition level? To make it clearer, I would hope there is some field could be used to define the record as ‘read-only’, that is all external CA put request should be denied, the data only could be updated through the internal device support.
Tong
Complexity comes for free, Simplicity you have to work for.
RE: Write permission of a record Zhang, Tong via Tech-talk
Prev: Re: Write permission of a record Arnold, Ned D. via Tech-talk
Next: Re: Write permission of a record Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: RE: Write permission of a record Zhang, Tong via Tech-talk
