I get it that you'd like to avoid channel access security, but eventually each IOC likely needs it, and you can get started simply like this:
# Example access security config file
ASG(DEFAULT)
RULE(1, READ)
RULE(1, WRITE)
ASG(READONLY)
RULE(1, READ)
# Nothing in here about WRITE...
Now you can configure records with
field(ASG, "READONLY")
and they will be read-only. So "there is some field ...to define the record as ‘read-only’", exactly as you wanted.
- Write permission of a record Zhang, Tong via Tech-talk
Re: Write permission of a record Andrew Johnson via Tech-talk
Re: autosave problem Laurenz Rettig via Tech-talk
<2022>
2025
2026
RE: Write permission of a record Zhang, Tong via Tech-talk
streamdevice in command only 2048 length 孙彬 via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
