Title: signature text
Hi Marco,
why don't you use a mbbiDirect record to read the modbus register
and then 16 bi records pointing the INP fields of the bi records
to the mbbiRecord's B0..BF fields.
- rolf -
On 2022-08-04 7:19 a.m., Marco A. Barra
Montevechi Filho via Tech-talk wrote:
Good morning, all!
Im trying to implement the transform field in an IOC but im not
getting the expected result:
i have an analog in record reading a bitmask
value from a modbus register. Since the bitmask has 16 bits, i
want to perform 16 bitwise operations to transform each bit in a
binary in record thus transforming each 0 or 1
into a different string.
Since i dont want to need to create 16 calcout
records, i thought i could use the
transform record to perform all bitwise
operations and push each one of them into a different
binary in record. So after reading the
documentation i tried to perform a calculation with
transform just for testing:
record(ai,
"${BL}:${H}:${EQ}:BitmaskGetter")
field(DESC,
"Bitmask
used by other pvs.")
field(DTYP,"asynInt32")
field(INP,"@asyn(SIP_EMODBUS_1_1_Rd_Status,0,1000)MODBUS_DATA")
field(SCAN,
"I/O Intr")
field(FLNK,
"${BL}:${H}:${EQ}:StatusSeparator")
record(transform,
"${BL}:${H}:${EQ}:StatusSeparator"){
field(DESC,
"PV to
process status bitmask")
field(INPA,
"${BL}:${H}:${EQ}:StatusBitmask")
field(CLCA,
"A+1")
field(OUTA,
"${BL}:${H}:${EQ}:EnableStatus")
field(SCAN,
"Passive")
record(bi,
"${BL}:${H}:${EQ}:EnableStatus"){
field(DESC,
"Power
supply status")
field(ZNAM,
"Stopped")
field(ONAM,
"Started")
So i expected that while caget in BitmaskGetter returns 0, caget
into StatusSeparator.A would return 1 and EnableStatus would
return "Started". It is not what happens: StatusSeparator
returns 0 and EnableStatus returns "Stopped".
To test if the calculation is right, i tried substituting the transform
record to a
calc one:
record(ai,
field(DESC,
"Bitmask
field(SCAN,
"I/O Intr")
field(FLNK,
"test_calc")
record(calcout,
"${BL}:${H}:${EQ}:StatusSeparator""){
field(DESC,
"PV to
field(INPA,
field(CALC,
"A+1")
field(OUT,
record(bi,
field(DESC,
"Power
supply status")
field(ZNAM,
"Stopped")
field(ONAM,
"Started")
And now caget into StatusSeparator returns 1, StatusSeparator.A
returns 0, BitmaskGetter returns 0 and EnableStatus returns
"Started", as expected.
So i figure field OUTA from the transform record
pushes the value in field A (which is zero) to the EnableStatus
link. If this is the case, is there any way at all to push the
result from CLCA to the EnableStatus link? Also,in which field
is the result from CLCA field stored, if any?
Thanks in advance,
Marco
Aviso Legal: Esta mensagem e seus
anexos podem conter informações confidenciais e/ou de uso
restrito. Observe atentamente seu conteúdo e considere
eventual consulta ao remetente antes de copiá-la, divulgá-la
ou distribuí-la. Se você recebeu esta mensagem por engano,
por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its
attachments may contain confidential and/or privileged
information. Observe its content carefully and consider
possible querying to the sender before copying, disclosing
or distributing it. If you have received this email by
mistake, please notify the sender and delete it immediately.
Rolf Keitel, Ph.D.
Researcher Emeritus
Office:
TRIUMF, 4004 Wesbrook Mall
Vancouver, BC, V6T 2A3
604 222 7453
Home:
4158 West 13th Ave
Vancouver, BC, V6R 2T6
604 228 0594
e-mail: rolf at triumf.ca
- Re: Implementing transform field Brown, Garth via Tech-talk
- Implementing transform field Marco A. Barra Montevechi Filho via Tech-talk
Re: Implementing transform field Andrew Johnson via Tech-talk
Re: Implementing transform field Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
<2022>
2025
