I want to use a different number of columns depending upon the user configuration.
I have the following queries
1) Can I change the structDict to another
struct2Dict and update the PV. The API
getIntrospectionDict or getStructureDict can only get the existing structure. Is there any API to modify/update the structure of the pv object at runtime?
You cannot change record structure definition at runtime, but you can easily remove old record and add new one:
>>> from pvapy import *
>>> nt = NtTable(3, DOUBLE)
>>> print(nt)
epics:nt/NTTable:1.0
string[] labels []
structure value
double[] column0 []
double[] column1 []
double[] column2 []
string descriptor
alarm_t alarm
int severity 0
int status 0
string message
time_t timeStamp
long secondsPastEpoch 0
int nanoseconds 0
int userTag 0
>>> s = PvaServer()
>>> s.addRecord('t', nt)
>>> c = Channel('t')
>>> pv = c.get()
>>> print(pv)
structure
structure value
double[] column0 []
double[] column1 []
double[] column2 []
>>> nt2 = NtTable(5, INT)
>>> s.update('t', nt2)
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
ValueError: structure definitions do not match
>>> s.removeRecord('t')
>>> s.addRecord('t', nt2)
>>> pv = c.get()
>>> print(pv)
structure
structure value
int[] column0 []
int[] column1 []
int[] column2 []
int[] column3 []
int[] column4 []
2) In the epics:nt/NTTable:1.0"
object all the columns should have the same number of elements/rows. Is it possible to have different number elements/rows in different columns. Presently I am
filling the empty ones with null string.
Yes, something like this will work:
>>> nt2.setColumn(1, [1,2,3])
>>> nt2.setColumn(2, [1,2,3,4,5,6])
>>> print(nt2)
string[] labels []
structure value
int[] column0 []
int[] column1 [1,2,3]
int[] column2 [1,2,3,4,5,6]
int[] column3 []
int[] column4 []
3) Is it possible to have the number of columns of the NTTable PvObject to be programmable at run time. similar to as in C functions printf(char*, ...)
Yes, you can add/remove records at runtime, and hence you can change it however you like.
I hope this helps,
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
sveseli at anl.gov
(630)252-9182
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Kuldeep Joshi via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, August 11, 2022 6:35 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: pypva, PvObject and NTTable
2) In the epics:nt/NTTable:1.0" object all the columns should have the same number of elements/rows. Is it possible to have different number elements/rows in different columns. Presently I am filling the empty ones with null string.
Regarding this point, it seems the limitation is due to the Phoebus table widget.
Hello,
I am using a pypva server and publishing a NTTable object. This object is being displayed using the table widget of phoebus
tablePV = PvObject(structDict, "epics:nt/NTTable:1.0")
1) Can I change the structDict to another struct2Dict and update the PV. The API
Presently I am deleting the PvObject and adding one with modified the structure Dictionary.
Thank you in advance.
Kuldeep
- Re: pypva, PvObject and NTTable Veseli, Sinisa via Tech-talk
- pypva, PvObject and NTTable Kuldeep Joshi via Tech-talk
- Re: pypva, PvObject and NTTable Kuldeep Joshi via Tech-talk
Re: Scan overflow issue Ralph Lange via Tech-talk
<2022>
<2022>
