On 8/12/22 10:03, Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk wrote:
%Parameters.template$(DEP): $(TOP)/pvi/%.pvi.producer.yaml
@$(RM) $@> echo "%Parameters.template: $(TOP)/pvi/%.pvi.producer.yaml" > $@
I don't think that replicating the .template dependency is the
right way to go. The purpose of a $(DEP) file is to capture
indirect dependencies. eg. if your .yaml file contains
references to other files.
A look at rules for MSI might be informative.
$ git grep -iB3 MSI3 -- configure/
configure/CONFIG_DATABASE_MODULE-
configure/CONFIG_DATABASE_MODULE-# Windows can need these paths to be quoted
configure/CONFIG_DATABASE_MODULE-MAKEBPT = "$(EPICS_BASE_HOST_BIN)/makeBpt$(HOSTEXE)"
configure/CONFIG_DATABASE_MODULE:MSI3_15 = "$(EPICS_BASE_HOST_BIN)/msi$(HOSTEXE)"
configure/RULES.Db-
configure/RULES.Db-%.db$(DEP): %$(SUBST_SUFFIX)
configure/RULES.Db- @$(RM) $@
configure/RULES.Db: $(MSI3_15) -D $(DBFLAGS) -o $(COMMONDEP_TARGET) -S$< $(TEMPLATE_FILENAME) > $@
configure/RULES.Db-$(COMMON_DIR)/%.db: %$(SUBST_SUFFIX)
configure/RULES.Db- $(ECHO) "Inflating database from $< $(TEMPLATE_FILENAME)"
configure/RULES.Db- @$(RM) $(notdir $@)
configure/RULES.Db: $(MSI3_15) $(DBFLAGS) -o $(notdir $@) -S$< $(TEMPLATE_FILENAME)
Where
$ git grep '^\s*COMMONDEP_TARGET'
configure/RULES.Db:COMMONDEP_TARGET = $(COMMON_DIR)/$(basename $@)
An example end result when expanding a evr-pmc-230.substitutions file:
$ cat mrfioc2/evrMrmApp/Db/O.linux-x86_64/evr-pmc-230.db.d
../O.Common/evr-pmc-230.db: ../mrmevrbase.template \
../../../db/evrbase.db \
../../../mrmShared/Db/databuftx.db \
../../../mrmShared/Db/databuftxCtrl.db \
../mrmevrbufrx.db \
../../../mrmShared/Db/sfp.db \
../../../db/evrmap.db \
../../../db/evrevent.db \
../../../db/evrscale.db \
../mrmevrout.db \
../mrmevroutint.db \
../../../db/evrpulser.db \
../../../db/evrpulsermap.db \
../../../db/evrin.db
Another common thing to do is to emit a dependency on
"../Makefile" to (hopefully) regenerate if the rules
are changed. (more less guaranteed while you are
trying to get this working)
- Makefile rule differences with base 3.14 vs 3.15+ in ADCore build with pvi Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
- Re: Makefile rule differences with base 3.14 vs 3.15+ in ADCore build with pvi Andrew Johnson via Tech-talk
- Re: Makefile rule differences with base 3.14 vs 3.15+ in ADCore build with pvi Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Re: forcing rpath Michael Davidsaver via Tech-talk
How to input TIME field values in aSub record types? Amin Hosseini Nejad via Tech-talk
<2022>
2025
pypva, PvObject and NTTable Kuldeep Joshi via Tech-talk
<2022>
2025
