1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: RTEMS 5 Cannot Read Event Generator
From: Andrew Johnson via Tech-talk <[email protected]>
To: [email protected], "[email protected]" <[email protected]>
Date: Wed, 17 Aug 2022 11:42:18 -0500
On 8/17/22 4:03 AM, chengsn via Tech-talk wrote:
I try to running the mrfEventSystem driver with EPICS 7 on RTEMS 5. After modifying part of the code, the driver can read the EVR(EVent Reciever) Card, and it works well. But when I run the driver and use the EVG(EVent Generator), I get this error: EgConfigure: Unable to read Event Generator Card 0 (slot 3) at VME/A24 address 0x1800000.
In st.cmd file, the configuration for the EVG is EgConfigure(0, 3, 0x1800000). When I change the OS from RTEMS to vxWorks(on MVME6100 and MVME5500), the driver can read the EVG.
0x1800000 = 0x01800000 is not a valid VME A24 address, it has too many digits set to fit into 24 bits. Have you tried say 0x00800000 instead, or did you mean 0x00180000?
Here is the hardware I am using:
 EVG: VME-EVG-230.
 EVR: VME-EVG-230-RF.
 Single board computer: MVME6100 and MVME5500.
The software:
 mrfEventSystem Driver Version: MRF Series 200 Event System Software Release V2-4.
Ahh, that's not the mrfioc2 module which explains why you're using EgConfigure() to register the card.
The value of ret: EVR returns 0; EVG returns 0x88FD0000 (in vxWorks and RTEMS, sizeof(long) = 8).
Do you have any suggestions?
The fact that you can talk to the EVR at that address from one OS but not the other implies that VxWorks may be masking off the high byte to generate its A24 address, but RTEMS doesn't.
The other suggestion I have for that situation would be that the VME address modifiers used might be different from the two VME bus interface drivers, but I think you should fix the address length before looking into that.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
Prev: Re: areaDetector synchronization question Mark Rivers via Tech-talk
Next: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
Next: Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
