Hi all,
I'm trying to determine the feasibility of using EPICS for simple monitoring of a small clean room facility. We'll need to read out various sensors (particle counters, temperature, etc.) via Modbus over Ethernet and archive the data at low speed (a few times per minute maybe) and also ideally display live data to lab users on a GUI (e.g. MEDM or modern equivalents). We're probably going to have a small number of outputs as well: automated switching of lights, fans, motors, that kind of thing. Maybe some alarms for e.g. triggering a warning light if particle counts get too high. No closed loops.
We could probably just use LabVIEW or similar but I don't like it much and prefer a licence-free and open source solution that can be easily adapted as needed. Plus, I may clone the EPICS setup to a different lab in a different city that we work with, so it would be nice to be able to use a gateway to access and archive their channels as well.
Has anyone used EPICS on such a small scale? Was it more trouble than it was worth compared to turnkey commercial solutions?
Any input would be appreciated!
Sean Leavey
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
- Re: EPICS for a small lab - overkill? Arnold, Ned D. via Tech-talk
- Re: EPICS for a small lab - overkill? John Dobbins via Tech-talk
- Re: EPICS for a small lab - overkill? boj via Tech-talk
Re: RTEMS 5 Cannot Read Event Generator Andrew Johnson via Tech-talk
<2022>
2025
2026
Re: areaDetector synchronization question Mark Rivers via Tech-talk
<2022>
2025
2026
