1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: EPICS for a small lab - overkill?
To: [email protected]
Date: Mon, 22 Aug 2022 10:31:51 +0200
Hi sorry for a late response to this subject,
I am having a very similar setup to what you are describing, and are very happy about it.
System is setup like this
* All is based on debian linux,
    with epics and modules as packages
    We compiled packages from https://github.com/epicsdeb
*    I made a "generic" ioc packaged, based on https://github.com/epicsdeb/epics-template
    Including the needed modules (stream-device, auto-save ....)
* All IOC's then just consists of database, protocol files and startup files (as all binary are in the deb packages)     These are keep in a git repository, for easy backup, and change tacking.
* For archiving I use the archiver applicance, which is really easy to setup, and does all for you
* For alarms I use a small how brewed python script to just send mails in case of alarms
* I have a small script generating a web page with graphs for easy checking the labs from eq my phone.
Having the major parts based on debian packages, makes installing new and upgrading IOC's very simple. I will be very happy to discuss / share info on this and other approaches for small lav use of EPICS.
Best
    Bo Jakobsen
On 17-08-2022 21:26, Sean Leavey - STFC UKRI via Tech-talk wrote:
Hi all,
I'm trying to determine the feasibility of using EPICS for simple monitoring of a small clean room facility. We'll need to read out various sensors (particle counters, temperature, etc.) via Modbus over Ethernet and archive the data at low speed (a few times per minute maybe) and also ideally display live data to lab users on a GUI (e.g. MEDM or modern equivalents). We're probably going to have a small number of outputs as well: automated switching of lights, fans, motors, that kind of thing. Maybe some alarms for e.g. triggering a warning light if particle counts get too high. No closed loops.
We could probably just use LabVIEW or similar but I don't like it much and prefer a licence-free and open source solution that can be easily adapted as needed. Plus, I may clone the EPICS setup to a different lab in a different city that we work with, so it would be nice to be able to use a gateway to access and archive their channels as well.
Has anyone used EPICS on such a small scale? Was it more trouble than it was worth compared to turnkey commercial solutions?
Any input would be appreciated!
Sean Leavey
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Prev: Re: Re: Re: Re: RTEMS 5 Cannot Read Event Generator Hamadyk, Paul (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: make release freezes terminal in synApps installation Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Next: olog docker question Silver via Tech-talk
