> If you are learning EPICS , Control System Studio, the Archiver Appliance, the Alarm Server, it might not be worth the time invested.
I previously used EPICS in the context of LIGO, where we built a real time control system on top of it so much of the software tools were custom. I've used the CA tools but not the CSS, Archiver Appliance or Alarm Server stuff, though I'm happy to dive in and learn it if it's feasible for our small lab. I'm hoping most of that won't be needed though.
Sent: 17 August 2022 20:43
To: tech-talk at aps.anl.gov; Leavey, Sean (STFC,ROE,UKATC)
Subject: Re: EPICS for a small lab - overkill?
My two cents:
If you are already familiar with EPICS (or have support from people who are) I would say sure.
If you will be using existing device support, that is another point on the plus side.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu<http://www.chess.cornell.edu/>
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sean Leavey - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, August 17, 2022 3:26 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: EPICS for a small lab - overkill?
Hi all,
I'm trying to determine the feasibility of using EPICS for simple monitoring of a small clean room facility. We'll need to read out various sensors (particle counters, temperature, etc.) via Modbus over Ethernet and archive the data at low speed (a few times per minute maybe) and also ideally display live data to lab users on a GUI (e.g. MEDM or modern equivalents). We're probably going to have a small number of outputs as well: automated switching of lights, fans, motors, that kind of thing. Maybe some alarms for e.g. triggering a warning light if particle counts get too high. No closed loops.
We could probably just use LabVIEW or similar but I don't like it much and prefer a licence-free and open source solution that can be easily adapted as needed. Plus, I may clone the EPICS setup to a different lab in a different city that we work with, so it would be nice to be able to use a gateway to access and archive their channels as well.
Has anyone used EPICS on such a small scale? Was it more trouble than it was worth compared to turnkey commercial solutions?
Any input would be appreciated!
Sean Leavey
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
- EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
- Re: EPICS for a small lab - overkill? John Dobbins via Tech-talk
Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Re: EPICS for a small lab - overkill? J. Lewis Muir via Tech-talk
<2022>
2025
Re: EPICS for a small lab - overkill? boj via Tech-talk
<2022>
2025
