1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: RTEMS 5 Cannot Read Event Generator
From: "Hamadyk, Paul \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 18 Aug 2022 07:23:24 +0000
I have performed some basic tests with the EVG using the mrfTiming driver with RTEMS 5 and EPICS 7 on an mvme5500. Look at MRF_CONFIG_SITE in mrfApp/src. It says this:
# If you don't know which address modifier your BSP uses for the A24 window,
# then just select one of the answers below (you have a 50% chance of being
# right).  Load the software onto an IOC that contains an Event Generator or
# an Event Recevier card and call either the "EgConfigure" or "ErConfigure"
# routine.  If the routine fails with a message of the form:
#    "Unable to read Event Generator/Receiver Card x (Slot y) at VME/A24
#     address ......",
# then you chose the wrong option.
I created the config file MRF_CONFIG_SITE_RTEMS-beatnik and set these options:
EPICS_SUPPORTS_CRCSR = YES
BSP_SUPPORTS_CRCSR = YES
ADDRESS_MODE = SUPERVISOR
Do you have the same settings? My base address was set to 0x10000 for the EVG and 0x0 for the EVR, both in the same crate. Here is my A24 address configuration, which should be the default:
Universe Master Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
1:    0x00000000 0x00ff0000 0x9f000000 A24, D64 [MBLT], Dat, Sup
Paul.
From: Tech-talk <[email protected]> on behalf of chengsn via Tech-talk <[email protected]>
Sent: 17 August 2022 10:03
To: [email protected]
Subject: RTEMS 5 Cannot Read Event Generator
Hello all,
I try to running the mrfEventSystem driver with EPICS 7 on RTEMS 5. After modifying part of the code, the driver can read the EVR(EVent Reciever) Card, and it works well. But when I run the driver and use the EVG(EVent Generator), I get this error: EgConfigure: Unable to read Event Generator Card 0 (slot 3) at VME/A24 address 0x1800000.
In st.cmd file, the configuration for the EVG is EgConfigure(0, 3, 0x1800000). When I change the OS from RTEMS to vxWorks(on MVME6100 and MVME5500), the driver can read the EVG.
Here is the hardware I am using:
 EVG: VME-EVG-230.
 EVR: VME-EVG-230-RF.
 Single board computer: MVME6100 and MVME5500.
The software:
 mrfEventSystem Driver Version: MRF Series 200 Event System Software Release V2-4.
 EPICS Version: 7.0.6.1
 RTEMS Version: 5
I also compared the difference between the return value of EVG and EVR in the process of calling the function devReadProbe()(devReadProbe(sizeof(epicsUInt16), pEg, &Junk) and devReadProbe(sizeof(epicsUInt16), pEr, &Junk)).The source of the difference in the return value of devReadProbe() is that the return value of the RTEMS function _BSP_clear_hostbridge_errors() is different. The function as follows:
unsigned long
_BSP_clear_hostbridge_errors(int enableMCP, int quiet)
unsigned long rval;
/* MCP is not connected */
if ( enableMCP )
return -1;
rval  = (clear_hose_errors(0, quiet) & PCI_ERR_BITS)>>8;
rval |= clear_hose_errors(BSP_pci_hose1_bus_base, quiet) & PCI_ERR_BITS;
/* Tsi148 doesn't propagate VME bus errors to PCI status reg. */
if ( _BSP_clear_vmebridge_errors )
rval |= _BSP_clear_vmebridge_errors(quiet)<<16;
return rval;
(ret = _BSP_clear_hostbridge_errors(0,1); )
The ret is return value of the bspExtMemProbe().
The value of ret: EVR returns 0; EVG returns 0x88FD0000 (in vxWorks and RTEMS, sizeof(long) = 8).
Do you have any suggestions?
Thank you!
chengsn
IHEP
Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
Prev: Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
Next: RE: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
